09Tahoe4Now
- Joined
- Jul 30, 2018
- Posts
- 97
- Reaction score
- 129
Okay guys and gals, I need your help. The rear doors are randomly sticking and failing to unlock intermittently. Sometimes they will unlock (more prominently seen in the rear passenger door) and my daughter can get in without a problem, at other times, I’m required to lean the front seat back, reach back and raise up the latch to unlock the door. You can hear the door lock wanting to do its job and see slight movement of the latch but it just don’t pop up. The last time this occurred with the passenger side I simply removed the door panel, made sure everything was on track, reinstalled and no issues until now. To make it worse, the rear driver’s side has decided to get in on the prank!!
I will be replacing the door speakers this week if I’m lucky. So, what can I do to address my two prankish latches? Graphite lube, white lithium grease, wd40....??? I miss get add that this may be a problem that was exacerbated by my daughter pulling on the door handle as I was trying to remotely unlock it. Not 100% sure but it’s possible.
I’m sure it’s a quick fix, I’d just like to knock it out once and not return to it again.
Thanks in advance for the suggestions, replies and knowledge.
