Intake manifold repair help.
U
Hmmm...
Lower intake is installed, new bolts tightened to specs. But I'm having some issues getting this new distributor installed. Any suggestions on how to turn the oil pump? I could get it seated all the way, but I'm not sure it was aligned properly. Best way to to tell if the housing is aligned correctly?
east302
Mississippi
Use a long flathead screwdriver to rotate the pump shaft. If you lay down on top of it with a light, you can just see it.
If you marked the distributor base and also where the rotor pointed relative to the distributor housing before it was removed, turn the rotor about 45-degrees counterclockwise from that mark. Also align base shaft with your mark on the intake. As it seats, the rotor will rotate to your original mark.
U
If you marked where the rotor pointed relative to the distributor housing, turn the rotor about 45-degrees counterclockwise. As it seats, it will rotate to your original mark.
I'll try to look down into it with a light. I need to buy a longer screwdriver, none of mine are long enough.
However, it's a new distributor and any marks I had on it were removed when it was soda blasted.
east302
Mississippi
If you have the old distributor and its marks, copy them to your new one. From there, even with no mark on the intake, I'd try to seat it such that the distributor cap hold down screw closest to the driver side is just hitting the intake...maybe 1/16" or something like that.
Edit: if you don't have the old distributor to transfer the rotor position marks, you'll need to rotate #1 cylinder to TDC and go from there. Here's a link...
http://www.gmtruckcentral.com/articles/distributor.html
U
Got the distributor in. "had" to buy some new tools. [emoji12]
Uh oh. What the heck did this come from??! Too much time has elapsed since I took this thing apart.
east302
Mississippi
I did the same job on my 98 last year, but the part doesn't look familiar.
It reminds me of the timing marker pointer thing, but I may be thinking of a Ford.
Kenny D
Crosby, Tx
Probably a tab to hold a wire clamp or something. From all the crud on it, it was probably close to the back of the intake around the valve covers or oil pressure sending unit.
U
I know the bracket is attached to the steering pump somewhere. I just stuck it on the bottom[emoji23]
So close!
Changed the plugs and wires while I was in there. Some were not tight at all.
I need a few additional parts. Anyone know this intake seal part number?
east302
Mississippi
Here's that bracket on the PS pump on my 98. Sounds like you found the right spot for it.
As for that gasket on the resonator, it may be time for a junk yard run.
U
It's alive!
Except it's kicking a throttle position sensor code. It also hesitates when you throttle it up from idle. Also spits out a bit of smoke too.
U
Cam sensor was because I'm an idiot and forgot to plug it in!
east302
Mississippi
Hey if you only missed one wiring connection out of the several dozen removed, then that's a win in my book.
Here is the diagnostic for P0122...
TPS connector...
U
OK. I was able to figure out why the sensor was not functioning. It didn't have any of the internal parts! And me being the idiot I am, didn't check it before I installed it.
That problem is fixed, no more codes!!
But wait, there's more...
U
Before I parked this thing to work on it, it didn't smoke at all. Now however, there is an excessive amount of steam coming out of the tailpipe. This is after running for 30 min and driving for a couple more.
[emoji43][emoji37]
Sorry for the bad camera work...
So what do you think? Head gasket? Intake leak?
Anyone have some c4??[emoji35][emoji35][emoji35]
U
Checked it again this morning. No smoke. At all. No steam. Nothing.
Went for a careful drive. Nothing. Went for a spirited drive. Nothing. What the heck? Could the weather really have caused that much steam? Could there have been that much condensation in the exhaust system? I'm baffled at this point.
east302
Mississippi
If your coolant level stays constant, then I'd think that your ok.
I remember mine smoked for a day or so but went away. I assume it was just from being left open for so long...I worked on mine intermittently over two or three weeks.
U
[emoji15][emoji43][emoji19][emoji53]☹️[emoji35]
TejasPitt
