Installing front lowering keys
FLHOE
Florida
Finally pulled the trigger and bought 2/3 pro kit and the front/rear sway bars from eibach. Trying to do some research on the best way to install the new keys in the front. Is there a special tool or a diy way to unload the torsion bars?
vjr021
Clearwater, FL
Once you get everything installed, let me know how it goes, I'm debating on a McG's 2/3 and Hellwig Sways, or the Eibach pkg.
Do a full write up with pics...
Badluck
SE WI
There is a torsion bar tool but I couldn't justify the $100 for a tool I'd use a couple times. Check ebay, that is the only place I could find one. I used a 2 arm pulley puller to remove the keys. Mine were rusted in good. I had to use heat, small sledge hammer, and patience to get mine out. Make sure the front wheels are off the ground when taking out the keys.
Kat Killa
GMFS has a really good thread that I looked @ before I did mine. #1 piece of advice- WD40 before you start and as soon as possible. Use a 7 ton gear puller.
Badluck
SE WI
Forgot to mention I sprayed the keys with plenty of PB blaster.
tybardy
everyone needs a Hoe
Gilbert Arizona
The keys were the EASY part when I dropped my truck... the rear shocks, somehow, really wrecked my day! hahaha
Seriously though, I went and bought a massive heavy duty c-clamp. Broke the flat part off so it was just a ball that sits nicely in that little dimple on the key. I have heard some horror storied about tortion bars unloading into an arm, but with as huge as the c-clamp was that I used, I had no problems.
Narco
Atlanta
has anyone done a tech how-to write up on suspension drops? ive never done it but bet that my buddy and i could do it
F
FLHOE
Florida
The lowering kit was on back order and did not get delivered until mid January. Finally had time and I installed the kit this weekend. At this time the front is a little to low compared to the back. Once the back settles I will adjust to get the look I want and then get the alignment done next weekend. I will post pics once it is complete.
The ride is very sporty but can be a little rough. I did install with my Z71 shocks since they are still good. I am wondering if I need to get different shocks.
Narco
Atlanta
my front rides ok on smooth roads but is VERY bumpy on ****** roads. i had to drive down several brick/cobblestone streets in tampa last week and was losing my mind it rode so bad! i still have the oem shocks on the front. dont know if swapping them out for some hd bilsteins would help or not.
F
FLHOE
Florida
The pic is not that good, need to take it before it gets dark.
Also adjusted the front, think I like it when it was a little lower.
Narco
Atlanta
im gonna try the drilling holes in the bumpstops he was talking about
Travieso
Boooooooost !
Los Skandeles, CA
i would try going with z71 bump-stops my truck rides so much better with them, even though i still have factory keys (soon to be change)
ZaZaZazzels
