Installed 2016 Wheels on 2009 - TMPS Issue
Kharoldsen
Hello All. I replaced my 2009 LTZ wheels with a LTZ set from a 2016. I tried to relearn the TPMS and it doesn't sense the new wheels. I stopped by a local tire shop and the tech tried to use his programmer, then told me that the sensors were bad. Are these sensors not compatible with my 2009?
mals
Western Mass
Hello All. I replaced my 2009 LTZ wheels with a LTZ set from a 2016..... Are these sensors not compatible with my 2009?
I recently installed some NNBS wheels on my NBS Yukon. In doing so I learned that while they all operate on the same 315hz frequency the BCM protocols are different between 05-06 and 07-14. I would assume that since the sensors in the wheels that I purchased had an upper match at '14 that a new protocol was introduced in' 15.
I purchased new AC Delco TPMS sensors from Amazon and had them installed and balanced a a local tire shop.
Elliott
I bought a set of 2016 LTZ Suburban wheels for my 2007 Yukon XL and had Discount Tire install them so i could pay for the certificates on the new tires(they only had 16 miles on them) they unbolted my wheels and installed the new set. i was in and out in 20 mins. TPMS works with the sensors in the new wheels
mals
Western Mass
I bought a set of 2016 LTZ Suburban wheels for my 2007 Yukon XL .... TPMS works with the sensors in the new wheels
Well, an actual working installation trumps my semi-educated guess of an explanation. I guess that's what I get for assuming.
K
Kharoldsen
Did they swap your tmps with the old ones, or leave the 2016 sensors installed?
DaRosa218
The Dude abides
Modesto, California
2016 Sensors will not work on a 2007-2014. I had the same issue, I asked the dealership as well as several reputable tire shops and they all confirmed they're non-compatible. I'd just have a shop replace them or pull your old sensors and install them on the 2016 setup. As for me, I went back to my stock Z71 rims since they looked better IMO.
K
Kharoldsen
Thank you! I plan to get replacements.
varminpoolteam
