I need a lube job!
foreverfalcon40
My suspension is squeakin and creakin every turn and bump I make.
I'm holding off till I do my brakes and rear axel seal.
Where should I lube this thing up?
qlc1964
qlc1964
you may have bad Aframe bushings or lower control bushings and you
can't lube thim
---------- Post added at 12:29 AM ---------- Previous post was at 12:28 AM ----------
them i mean.
foreverfalcon40
foreverfalcon40
Ok...I'll see when I throw her up on the lift monday. If so energy suspension ones will be on order.
YNOT
you can spray things down with white lithium grease it comes in a aresol can. it doesn't have a solvent in it like wd40.
foreverfalcon40
foreverfalcon40
Hmmmm I have a few of those cans lying around...usually spray that or pb blaster to break things loose. I'm looking for something more like actually physical grease...like in a can. I know we use a black grease sometimes to put on bolts at the shop.
ravingmadman
Chief Knuckle Buster
Greater Seattle
lithium grease comes in an aerosol. or if you have a good grease gun, you can pick up a lubrication nipple, that shoots a small stream out, and squirt it in there. It probably wouldn't hurt to grab a couple crescent wrenches, and just tighten everything up a little, too. Rattles start as squeaks. :)
CKendrick
