Huck's 2004 Yukon slow build
BADRIDES
The more drop will for sure help with that fender gap with the shorter tires. But man what is with you guys and the trucker spikes?
04Huck
04Huck
"I'd rather be lucky than good"
Buford, Ga
Lol I just like em :shrug: It’s different
04Huck
04Huck
Buford, Ga
This showed up today. Now just trying to decide if I wanna drop it and chance the pinion angle or wait until I can buy the relocation brackets for the LCAs or the Spohn LCAs. Not sure if I’ll run into issues at 4-4.5” in the rear
FWIW....I'm down ~4" in the rear and running that bar (along with the Spohn UCAs and LCAs) without any issue on my 07
04Huck
04Huck
Buford, Ga
But did you adjust them to set your pinion angle? I want to run those LCAs and UCAs eventually, but don’t have the fun money for them right now. But I don’t wanna wait forever to finish my drop either lol
I did adjust them a little bit, yes. With that said, I was dropped for a few years before I sprung for the Spohn stuff. I say that to say take your time. The Spohn stuff is nice but not a requirement by any means. If you were going further down it might be a different story but 4-4.5" is still considered pretty mild.
04Huck
04Huck
Buford, Ga
:Handshake: That's mainly what I'm concerned with, just don't want to go ahead and do the drop only to find out my pinion angle is completely Fubar'd and have to put it all back the way it is now. I'll be doing it all at once and don't want the front 2" lower than the rear lol.
Was going to do the install this weekend but it's NMRA/NMCA weekend at the dragstrip so me and my dad are going up there tomorrow :pepper:
04Huck
04Huck
Buford, Ga
Started here, after fighting the spindles yesterday evening. The finally came off with a bigger hammer
Broken cam on the drivers side
Front went back together pretty smoothly
Before free travel mod
During, my buddy Tony (some of you guys know him as b005ted from other forums) cleaning up the cut
After
04Huck
04Huck
Buford, Ga
Brackets
Panhard bar and new sway bar endlinks
Unfortunately the sway bar really does have to be relocated to the passenger side. The passenger side panhard bracket sat hard right on the sway bar
Finished the night off porting and polishing my new Belltech alignment cams. They didn’t freaking fit on the bolts!
Getting an alignment in the morning, MIGHT mod the rear sway bar if I have time, throw in the spare tire (to weight the rear down) and see if I like the rake. It’s sitting at ~27 1/8”-27 1/4” up front and ~28 in the rear. Not sure how I feel about the rake, may cut half a coil eventually
Brackets
Man, that's low. Nice work.
04Huck
04Huck
Buford, Ga
Thanks man. I guess I should clarify, that’s measured at the front (just behind the front tire) and rear (just in front of the rear tire) on the body line. The wheel wells aren’t even on these trucks so I don’t measure there
kwOH
Banned
Wheres the pic........?
Sent from my iPhone X using Tapatalk Pro
Deennoek
