How to remove 2nd row headrest?
AJMBLAZER
Paducah,KY
Trying to put the kids’ carseats in our 2022 Yukon. I watched a video online and discovered the trick to moving the little clip that lets the headrest move up. Problem is the passenger most side “leg” seems anchored in the seat now that the headrest is up about 4”. It can go back down but won’t go up past this point. Driver’s side leg on this seat seems like it might still pull up more.
Anyone done this?
normally you push the padding down around where the headreast pins/legs go into the seat back and you will see a pinhole or pinholes (one on each side) that is where you would insert a paper clip to push the pin in to release the "legs" and lift the headrest out.
AJMBLAZER
AJMBLAZER
Paducah,KY
No but kinda never had to. Got my kid’s seat adjusted well enough it didn’t matter.
Ep33401
