How to: Clean GPS Install
Narco
Atlanta
I had recently asked where some of you mounted your external GPS units. I didn't get an overwhelming response so I figured I'd do my own thing. I'm VERY picky about visible wires and don't like leaving things plugged in to the cig lighter.
Wife bought me a TomTom GPS for Xmas and an ipod to OEM adapter. The TomTom was too wide to put behind the panel where the tractional control is. Here's what I did:
Here is where I mounted it, you have to get rid of the traction control button
Go get something like this from radio shack for 9 bucks. From what I've read you can't just cut the cig cord and hardwire a GPS or you'll fry it b/c of the volts. I just cut these clamps off, hardwired this and plugged the GPS cig plug into that
Alcohol is your friend. Scrub the hell out of any surface your going to put the adhesive plate onto
Remove the dash trim
Traction control button once you take the box apart...I also shorted the light out. I just tucked the button back into the dash. That light gets hot and I didn't want it to touch a wire loom or something and end up burning through it
Put the blanks back in place and wipe them down with alcohol
Cut the clamps off. The positive can stay bare wire. Take the negative and crimp a horseshoe terminal on the wire...you'll be grounding it next.
I grounded it to this screw just above the parking brake
Now you need power. Make sure you use a fuse that has power ONLY when the key is on ACC or the truck is running. I used this 15A fuse on the top left part of the panel.
Put the adhesive disc on the blanks. Let it sit for awhile before mounting the GPS on it. Run the wire behind the carpet and up behind the dash over to the blanks and put the dash trim back in place
Final product
All in all I like having it here. I can unhook it easily when I'm not in the car and no wires are visible anywhere. I wanted to have power running to it when the truck is on but didn't want to have to plug and unplug it each time to get it. This works out well.
vamike78
VA
That's awesome! That's almost exactly what I want to do for my iPhone. I've got an '02 Tahoe with the OnStar box right there (that doesn't work), so I was planning on taking it out and putting a plain piece of plastic there to mount the cradle on.
Narco
Narco
Atlanta
im gonna get a swivel mount for my iphone and put it closer to me. while i had the dash apart i went ahead and installed the ipod adapter to use with the oem stereo. crutchfield sells lots of mounts.
DenaliAK
Colder than you
Alaska
Looks good. I've gotta come up with something to do with my iPhone. I didn't know there was an adapter for the OEM stereo...I'm going to have to look into that.
riding-dirty
Oshkosh, Wi
What kind of mount was that to the gps? Is the cradle there all the time or is it magnetic or something?
Thanks
Narco
Narco
Atlanta
its just a flat adhesive disc that the gps suction cups to...it all came with the gps as most do
Narco
Narco
Atlanta
^ thats what i wanted to do but the TomTom was too wide. My wife has a Garmin that would fit so I was gonna trade her but I quickly realized there was no way to turn it on and off. i could have set it up to charge and power on with the ignition but how do you turn it off when getting out of the car? it has an internal battery. didnt want someone breaking in my car for it.
01yukon
Lynchburg, Va
To get mine to turn on and off I installed a 12v cigarette lighter under the dash with a hidden switch to turn it on and off.
Narco
Narco
Atlanta
but how does that switch kill power instantly? doesnt it have an internal battery that charges as its on? if so killing the switch would stop power from going to it but the gps would still be running off its internal charge. this is the problem i ran in to.
vjr021
Clearwater, FL
It depends on your GPS, my Garmin will start to turn off as soon as it senses loss of 12V power...
Narco
Narco
Atlanta
my wifes garmin didnt do that. it stayed on or i would have swapped with her and used it. oh well. at least this way i can still take it in and out as needed.
---------- Post added at 01:03 PM ---------- Previous post was at 12:59 PM ----------
VJR, i like the proclips but DAMN theyre expensive. almost $80 bucks? its gonna cost almost as much as the GPS did!
ZaZaZazzels
