HOW-TO: 03-06 NBS Gauge cluster LED conversion
Tahoewhat
Ballin' on a Budget
TX
Just went through this thread and realized I never said anything back to scott.lol But no problem scott I was the guinea pig for quite a few things. lol. :happy160: Very much appreciated.
Just an update for anyone wondering. That is my cluster he did, in this thread, 1st time, I have had no problems since that then. No problems w/ any of my buttons he did.
Still holding up very well.
Sho'Tyme
Georgia
My rpm gauge is floating will that be fixed as well...also can you pm me ...I don't have enough post
ScottyBoy I tried to pm you but I haven't had enough post...can u pm me ur info so I can send u my cluster...thx
Sho'Tyme
Georgia
PMs replied to guys. :Handshake:
What's happening guys...just had my LEDS and all my motors done by Scott and you guy are right...he does amazing work...thanks a million Scott and Happy Holidays!!!!!!!!!!!
Tahoewhat
Ballin' on a Budget
TX
Looks really good Charles,
Scott does great work. hes finishing up some stuff for me.
ricetronaut
Houston
Scotty, Awesome work on the clusters! I am just wondering if the transmission (PRND321) and the Info Displays have their own LEDs (and what kind) that need to be replaced to match the other nine in the cluster?
abideejay
20' from the surface of the sun (otherwise known a
Hot Spots?
I am going to have to have my cluster rebuilt due to a failed stepper motor. There is a guy here locally that does them, but he says that the LEDs tend to have hot spots, where the lighting is bright in some areas and dimmer in others, as opposed to the incandescent lighting where it is more even.
Any thoughts to this? I'd really like to do white LEDs in mine while it is all torn apart.
izzy
Scotty great info, can you tell us what type of bulbs are needed to do all the other areas of the vehicle (climate control unit, steering wheel buttons, etc.)
THANKS
DJejizel
Scotty. What kind of LED did you use? Flat top or regular Leds? Dope write up!
I tore apart my gauges and put in, white flat top leds, and the cluster looks baby blue with hotspots?
Hey Scotty, I got a quick question for ya. I just did my cluster today and got a little carried away and replaced the bulbs in the black area of the cluster too. Now neither turn signal arrows on the cluster light up. What did I screw up and how can I fix it?
Thanks bro!!
Smoke Em All
Taylor,Texas
Subscribed for future reference. My stepper motors are on the way so I'll be doing leds while I'm in the dash.
clandr1
Dallas/Fort Worth, Texas
I know I'm 6 months late, but try lightly sanding the LEDs before installation. It should diffuse the light more evenly.
Smoke Em All
Taylor,Texas
Ok I got my LED bulbs and resistors in today and plan to get started soon. My only question is what is the easiest way to know which leg on the bulb is positive? One is longer than the other but, no markings or other differences to be seen.
skaffy03
West Des Moines, IA
There is actually a marking (usually) somewhere on an LED. But the easy way is that the positive is generally the longer leg.
You can always solder one LED to the board using the longer leg as positive then go back and plug the harness in and see if it lights up. You'll find out soon enough which is correct polarity (given that you soldered correctly) and then you can keep on going with the rest of the LEDs.
X-ray Nerd
