How much A/C freon
woody367
The ac in my 99 4dr Yukon with front and rear ac is not cold. System is very low.My info decal is missing so how much freon should a empty system take, 2.75lbs? I am going to replace the orifice tube the evacuate the system and add some dye. Do I need to add oil if just changing the orifice tube? Thank you
liquify33
Houston
GMT800 2005 Tahoe Z71
Navy Supporting Member
You should always replace the Receiver Drier/Accumulator if you open the system. What you do is up to you but you SHOULD. Make sure when you evacuate the system that when it is done and the vacuum is at the lowest it can go, shut it off and watch the needle. If it moves/climbs, you have a leak.
TheAutumnWind
http://www.techchoiceparts.com/refrigerant-and-oil-capacities/chevrolet-light-truck
64oz if I’m reading it right.
ETA: if you vacuum out and refill this may also help:
http://rechargeac.com/how-to/ac-system-pressure-char
As to oil I wouldn’t think so for an orifice tube, IIRC it’s around 3oz oil if you replace the drier (probably should if you don’t know it’s history).
If the system has a leak the drier needs replaced. Pour the oil out of the accumulater/drier and measure the volume and replace that amount. Replacing orifice tube does not require oil.
My 94 rcsb takes about 2 cans. Fill until your pressures are correct though, dont guess. Get a set of gauges.
woody367
woody367
So I found the decal and if I am reading right ir is 44oz for my Tukon with rear A/C. I will replace the dryer as it has never been changed before. Should I get 3 cans with the dye or just need 1 with dye and 2 without? Also is one brand of refrigerant better then another?
woody367
woody367
With the front and rear a/c is there a separate A/C Accumulator/Drier?
woody367
woody367
Ok Thank you. Is one brand of freon better the another? Should I use 3 cans with the dye or 1 can with dye and 2 without?
79jasper
Personally, I wouldn't buy refrigerant that has any mention of "seal conditioner" or stop leak.
If starting from empty, I would just add the dye separately. Add it between vacuuming and charging.
Sent from my SM-N960U using Tapatalk
TheAutumnWind
Its getting harder and harder to find the ones without stop leak. Ive seen them at walmart and home depot
imkwuzn
SoCal
, post: 1456935, member: 30756"]The ac in my 99 4dr Yukon with front and rear ac is not cold. System is very low.My info decal is missing so how much freon should a empty system take, 2.75lbs? I am going to replace the orifice tube the evacuate the system and add some dye. Do I need to add oil if just changing the orifice tube? Thank you[/QUOTE]
My 97 2 door holds exactly 3lbs or 1.36kg without rear AC. I’m surprised a 4 door would hold less than mine if equipped with rear AC?
I just did a complete AC replacement (compressor, orifice, evap/drier). Added new synthetic pag oil to compressor by hand prior to vacuum and recharge. I think it took 8oz total. If you’re only doing orifice tube, I would also recommend replacing the evap/drier as it is cheap and may be contaminated. A couple of oz in the new drier should be fine as most remains in the compressor. If you have access to a professional AC machine, it will measure the amount of oil it sucks out when you initially evacuate the refrigerant before you open the system if you haven’t already done that.
Regards
woody367
woody367
Ok, so after a month since I first started this post and being sidelined I am going to attempt to get this done. A few more questions as I am a little confused. I bought 4 cans of straight 134a, a orifice filter, a new drier and a can of A/C PRO PAG 46 oil charge 3 oz.
1} the decal on the old drier states 2lbs 122oz for a yukon/tahoe which seems low compaired to what google searcs show. Would this be right? See photo of my earlier post.
2}is the 3oz charge part of the total amount of freon as it is pressurized?
I just want to make sure as not to damaged anything. I was given the oil charge at AUTOZONE instead of just a bottle of oil to pour in. Also should the oil charge go in first or after 1 can iof freon in which is a 12oz can.
briannorris
