How do I fix a loose driver seat ?
James Ward
2015 Tahoe LT
SE Pennsylvania , West of Philadelphia
Anyone else have a slightly loose drivers seat ? It's not like it's going to fall off, but it's a nuisance of a flaw. The power options are great and work fine, but there's a little twitch every time I go around a corner or the like, and the seat moves a little bit. I can't see or feel any loose nuts or bolts, but it's still there ?
DWTahoe
Colorado
Very common thread on here. Try a search in a google window, I hear search on this site is broken. Paste the line below into Google
site:tahoeyukonforum.com driver seat loose
This will search this site specifically. You can change what you are searching for, just replace everything after the site (.com).
Basically you can go to your dealer and have them mess with the seat (and it might work). Or use a couple hose clamps underneath and stabilize it yourself.
Squats? Leg lifts? Donkey kicks?
capitalheel
My '17 Tahoe has the same issue, just an annoying subtle rock during some turns. Did you figure out a fix?
Tahoe14
Central Fl
Do a Google search as I believe there was others with this issue. I don't remember the fix. There may have been a bulletin. Good luck.
Laurents10
