How do I clean up and restore the finish on my running boards ?
James Ward
2015 Tahoe LT
SE Pennsylvania , West of Philadelphia
The finish on my 2015 Tahoe running boards are pretty beat up. It was a 39 month lease vehicle. The running boards show it's neglect, what can I do to fix them ? I tried Mothers Back to black, but it needs something more. Thank you !
If looking to just restore color--a fellow member has used krylon fusion to restore his black step pads, with good results, iirc--his name is @Rocket Man. Hopefully he'll chime in and correct me if I'm wrong.
Bob2C
Northern VA
I have used this on the black plastic parts on my truck from new. Helps with oxidation but can be slippery
adventurenali92
Big Bear Lake, ca
@adventurenali92 isn't there a chemical brothers product you like for this?
Chemical guys have many trim shine/protectant products that are fantastic in non stepping surfaces. Trim+tire gel is my favorite. I use it once in a while on my running board plastics to keep them from drying out. But that’s because I don’t have to step on them to get in and out of the truck. But it does make them pretty slick.
CMoore711
Another member had his fixed side steps coated in rhino liner. Turned out awesome, would take care of your finish problem, provide superior grip, and last forever. If you plan to keep the vehicle a while I’d consider doing that.
cmatt
A product called Solution Finish should help restore the color.
Sent from my iPad using Tapatalk
sd172
South Dakota
I just had the Z71 running bards (Part Number: 23196394) installed in place of the atrocious plastic ones that came with the truck. It wasn't even safe to use the factory ones in winter conditions when they are glazed over with ice. Just my 2 cents.
cameradude
Solution Finish is the way to go....will last about 6mo with typical use and washing. It's not slippery. If you want a more permanent finish try Cerakote Trim Coat...they've got some automotive finishes for plastic trim. A registered professional detailer in your area should be able to help you out also if not point you in the right direction.
I repainted all my black plastic with Krylon Fusion in satin black, still look like new 2 years later. It doesn’t make them any slippier than before, just don’t spray so much on that you fill in the texture. 2-3 light coats works great.
dcyy
View attachment 237772 View attachment 237773
I have always used Forever Black FB060 on my boards and vinyl trim-even on my Weathertechs-looks good
dcyy
I have always used Forever Black FB060 on the boards and vinyl trim-even on my Weathertechs-looks good
rgosart
I used forever black trim dye on mine. Good stuff so far... Not slick and it is easy to apply. Just as a warning, do not use the foam brush that is included. You need something more like a wax applicator pad. Otherwise you can see the streaks from the brush strokes.
HiHoeSilver
Away!
Chicago
Old school rit dye. Just be careful. Or what about that gummi pflege? People swear by that, too.
TallHoe 96 OBS
