How bad does a 0 offset stick out? Tried a search - no luck
ShawnQ
Bayou Vista, TX
Looking at a set of wheels, and I found a used set for a huge discount. 20x9 6x5.5 with a 0 offset.
Any input on how this looks?
I've got a Z71 with the flares, and will eventually go SLIGHTLY bigger on tires, and maybe a leveling kit but planning to lift it.
I don't mind the flush look, but don't want them setting out too far.
Thanks,
Shawn
Modded
That Guy
They will stick out way too fay. I have a +20 offset on my latest wheels and it stick out in the front like half an inch.
Anything less than a +15 offset would like bad.
AZSCTACO
Phoenix, AZ
Actually since his rims are a 9" wide wheel and I'm assuming Modded's 26's are a 10" wide wheel....it will only stick out about .8" farther than Modded's. So as long as your not planning on lowering the truck, and possibly lifting it....I think you'll be safe.
Modded
That Guy
It doesn't matter how wide the rim is, but how wide the tire is. If it's a 265 or 275 tire it won't stick out much at all. If it's 295 or 305, it will be way out the side.
A 9" rim with a +30 offset on a 295 tire sticks out just as much as a 10" +30 offset rim on a 295 tire.
Mohrgan
