Hot Wire Going to Rear-View Mirror?
bptexas
I have a 2008 Denali. Does anyone know which wire going to the rear view mirror is power (hot wire)? I'm looking to wire my radar detector so I don't have a wire hanging down.
Thanks,
Brian
hyde
Montgomery, Tx
Thanks,
Brian
Just tuck it all and then you dont splice anything....O yeah do you work for BP? John
KMeloney
Definitely go the Invisicord route. I did, and it works great. Off hand, I can't recall which slots you needed to use (I think there are two wires that need to be inserted in the harness). I'll see if I can remember to look at my truck and let you know.
For those suggesting you should run a wire from the fuse box, you need to check out using the rear view mirror. SO much easier, no pulling panels and fishing wire, and it works flawlessly. I ran wire to my fuse box in my '02 Tahoe (and also my Vette), but you just don't need to do that anymore.
Modded
That Guy
I suggest you use a fuse add on kit from Auto Zone and just power off one of the fuse box outlets that turn on/off with the vehicle.
CKendrick
