mikez71
- Joined
- Mar 9, 2023
- Posts
- 3,234
- Reaction score
- 4,008
thx, good to know! I like your wiring plan.
ok. Thanks for that explanation.the mega fuse really only protects the wire from the alt to the battery side of the fuse. incase it grounds out and dead shorts. or if the alternator internal shorts or something. if say from the battery postive terminal to basically any ground point anywheres touches, the battery can discharge way more than 300 amps and that fuse won't below. there's no protection provided by that meg fuse to anything else in the car. that's what the fuse block full of small 5 to 30amp fuses are for.
things like modules don't use more power because the source can supply more amps. you'd have to increase voltage to force more energy into something to damage it. like say putting a 24v alt on a 12v system would fry stuff, but never blow a fuse because it's voltage, not current. fuses are basically there to pop if there's a dead short and protect the wiring between the fuse and the short from catching fire.
to be honest, if you out a amp clamp meter on that B+ wire off the alt, with the truck running and read the current and then change the alt out and test again. unless your current alt can't keep up with the load you have on it now, you won't seen any difference in amp load on the meter. alt will only supply what is needed.
that is the reason I bought the mechan model I have because it is guaranteed to output *** at idle.Here is another thing for you to worry about and stress over.
High output alternators don't charge well at idle unless you spin them faster by using a smaller pulley.
Just thought I would throw that into the mix for you to get a hundred more opinions on.... lol
Path | Gauge | Approx. Length | Current It Carries |
| Factory Wire | ~4 AWG | 30–36" | ~70–100 A (20–30%) |
| New 0-Gauge | 0 AWG | 18–24" | ~270–300 A (70–80%) |
Step | Action |
| 1 | Keep all OEM wires + 175 A megafuse |
| 2 | Run 0-gauge from alternator → battery |
| 3 | Fuse it with 300 A ANL within 12" of battery |
| 4 | Clean/tighten factory grounds |
Mechman specifies that when you order. I told them my truck was modified and then they started asking more questions. They also stated that should I upgrade the motor to turn more revs than factory (e.g. rev the 5.3 to 7k+ rpm) that I would need to ship them back the alternator to put a different size pully on and other mods for it to be able to handle the higher RPMs and slower idle speed.Here is another thing for you to worry about and stress over.
Thanks!I have a Mechman 400amp in my truck.
Tony is a bit of a jerk - i had multiple emails with him as well.
Our trucks are a little different because of the added electronics on the later generations, but here is what I did.
I DID REPLACE Alt to Battery cable with a 0 gauge cable without a fuse from alternator to battery.
I DID NOT replace the OEM power cable that goes to the starter.
I DID REPLACE all the ground cables.
I added a 3 post ground terminal to my battery
0 Gauge from Battery to frame.
8 gauge from battery to body
8 guage from battery to engine
Added 8 guage from frame to engine
Added 8 guage from engine to body (firewall)
All wire was OFC oxygen free copper). I used copper ring connectors and heat shrink tubing over the ends.
End result was that my headlights no longer dim when the 1000watt sub hits and all my electrical gremlins disappeared. You can check my post history here and on reddit (Agitated-Carry7579) but my truck would literally "reboot" while I was driving. That hasn't happened since.
One correction - i was going from my recall and went out to grab some pics.Thanks!
How many of the ground cables from the B- were you able to fit through the RVC, and which ones? If you got that detailed in your other posts, then I'll check those out, too.
