hid off road light problems
the big blue bus
richmond, va
im having weird issues. i put some ddm 4500k hids in driving lights on grill guard. now i thought it was ballest but they still like to randomly pick wich one comes on and i have to flip my switch a frew times for them to come on. any ideas? never had any problems with my hedlight hids
the big blue bus
the big blue bus
richmond, va
moved the ground and that solved one of them. now it comes on everytime with switch but still not the drivers. someone said to flip the polarity of ballest. could that be it?
the big blue bus
the big blue bus
richmond, va
yes they both worked the first time when i had em in the bumper then one would flicker and since i moved em to grill guard that ones worked but now i cant get it to work
Ceejkay
Ft. Lauderdale, FL
ok harness isnt flipped if they worked before unless you un plugged them, also if you have your ballasts just floating in the breeze( not secured) you will blow the ballasts. also take a meter to make sure you have a FULL 12v going to them, ballasts dont like low power( also will blow them)
the big blue bus
the big blue bus
richmond, va
they aremounted by the rad and dont move. ill check that tonighit last i checked they had good power going to them around 13
SunlitComet
OBS Jedi-Do Good
unknown at this time.
the ddm are supposed to get the plug turned 180 normally. they were originally set up as a positive ground system. not negative ground like our vehicles.
chauncey0337
MLT, WA
Do you have a relay harness. I think it's flickering and not firing both bulbs because both ballasts are not getting the required voltage.
the big blue bus
the big blue bus
richmond, va
ive got them wired with a relay, 30amp i think from a ford. the power wire to and from relay is 14awg and the lights are grounded where the wire comes off battery to the fender. the passenger one always ignites always drivers when i flip switch.
ch4d
A Podunk town in Oregon
Found your problem your using a ford product lol but change the ground around a bit see if you find anywhere else that would work.
the big blue bus
the big blue bus
richmond, va
they are at the same ground and the passenger one always comes on drivers needs switch flipped. may try a nother ground for the drivers but atleast they both work now
cdhpc2
