HID fogs
my09denali
Do I need a relay harness when doing HID in fogs? I'm going to be getting 25W bulbs and 25W ballasts from Spencers.
Thanks.
Modded
That Guy
Haha Tahoe26 35W ones melt the housings pretty quick, a 50W one will melt it in the first 30 minutes of use.
25W is the way to go with HID fogs in the NNBS models.
Conor
"Bob's your Uncle"
Seattle, WA
X2, unless you are real carefull with the 35 watts. 50 watts are out of the question for fogs.
Another good option is LED bulbs in the fogs if you have 6000K HID headlights
bigblue
Beaumont TX
not to hijack the thread or anything, but what size are the fog lights? My truck didnt come with oem fog lights and i want to put some in it?
M
my09denali
thx guys.
I did buy some LED fogs but am completely clueless as to how these would install in the stock wiring harness
Conor
"Bob's your Uncle"
Seattle, WA
thx guys.
You should be able to snip the OEM harness and put the female ends on the oem harness and plug it in.
williajj
Minnesota
thx guys.
Just pop out the factory bulb and insert the metal prongs from the new bulb into the socket. The HID's will be the same, you'll just have to mount the ballast somewhere.
---------- Post added at 12:53 PM ---------- Previous post was at 12:51 PM ----------
Why isn't a relay harness necessary for the HID fogs?
The fogs don't have any of the issues that can damage the low beam HID's... automatic start-up flicker, DRL use, etc.
M
my09denali
So in the pic above remove the bulb from the gold socket?
I was looking the wiring harness after disconnecting the light above and saw no way those prongs would go anywhere.
thx guys.
JeffK
