help with piaa lights.
ch4d
A Podunk town in Oregon
so i got a set of piaa fog lights but when i got everything together the button shows no power to it but when i hit the button i hear the tick noise from the relay but no lights turn on or no power light is shown on the button.
What should i do now? I am trying to figure out what to do next to get the lights turned on. They wont turn on any help?
_Dylan_
STAY FROSTY
What kinda switch is it?
If you can hear the relay then the switch is working. Check fuses and grounds. Make sure the bulbs work by hooking directly to a battery. Maybe the relay is wired wrong?
C
ch4d
Well the ordeal is i took it off another rig and it worked fine before hand everything should be wired correctly
_Dylan_
STAY FROSTY
You aren't really helping me out bud. I need more details.
You could start by telling me which wires are going to which pins on the relay:
85-?
86-?
87-?
87a-?
30-?
What kind of switch is it?
C
ch4d
nvm found out the problem umm i used a power as a ground lol then the ground was connected to the battery whoops lol
ASG-MikeS
