Help with a '07 Tahoe rear end
pudge_the_fireman
Hello everyone..
I recently purchased an '07 Tahoe PPV and it looks like I need to have the rear end rebuilt according to my mechanic. It currently has a 3.73 gear and was wondering if I should lower it to a 3.08. The vehicle will never be in high speed pursuits anymore or have the need to tow anything. Mainly just interstate driving.
How much do you think the MPG increase with the 3.08?
Thanks in advance
vt_hokie2008
VA
MPG should go UP with the 3.08 as your engine rpm will be lower for higher speeds.
Blazed
Accepting Donations
According to gm your should get 21/15 with 3.08s I believe.
wardo
Look up a gear ratio calculator to find out the difference in rpm.
I doubt it will be much less and will probably not save you anything .
The truck will be more sluggish.
Also consider the cost for the swap, you will probably break even on the cost in ten years, ha.
tap a talka thingy
Blazed
Accepting Donations
tap a talka thingy
X2 sluggish.
Mine has the 3.08s it slow AF
Yukon11
Arkansas
I have a 2011 yukon with the 3.08s and the mpg on hwy are great, you can easily average 20mpgs...running a larger tire and/or city driving is not so great I was going to mention if you do decide to swap to 3.08 I would be interested in you current 3.73s. Is yours 4wd? Anyway, if you are not looking to tow and purley hwy driving i would go with the 3.08s.
Blazed
Accepting Donations
Do they make 3.73s for the front axle?
Blazed
Accepting Donations
Ah come on!!! Why is everything so hard?
Can I just get rid of the 4x4?
Regency
I have 3.43 I think it's perfect for me not sluggish at all but I don't get good mpgs what so evver never have never will
veteran111
