Help me “bulletproof” my K2500....
bondservant2
I’m really liking my 2011 Suburban 2500 SLT and am hoping to make it last another 20-years. Not a daily driver and it has 117k well kept miles on it. What should I be looking at for upgrades to the engine/driveline..? Currently it’s just a family cruiser but hoping to get a pull behind camper next spring. I’m already a fanatic about maintenance so we are good there. I saw someone mention a “transmission tune” in another thread....what would that consist of....?
OR VietVet
GMT800 2005 Tahoe Z71
Navy Supporting Member
Willamette Valley
Along with the absolute best you can do to keep the trans cool and tune it, as you said, the next thing I would do is beef up the suspension as much as possible to handle any loads being towed and have the right load rating tires on the rig. You may already have load range "E" tires and that is a good thing. You also want to keep the engine cool as well. The more you tow up and down hills/passes the more work you put the engine and trans through. Do you know the diff ratios? Synthetic fluids is a must. Make sure the drivelines and joints are in top notch condition. There will be others here that will give even more info/recommendations.
Tiki
Contact BlackBear tuning, get a trans cooler, regular maintenance. There is also a lot of suspension upgrades that can be had from aftermarket companies
flush cooling system, flush brake system, flush power steering system, replace heater hoses & "T's", 02 sensors (all 4 are due after 100k), belts, inspect all wires and looms and look for worn area's often from sitting and rubbing on the same spot for so many miles it helps to put new zip ties as needed here and there, plugs and wires are also due at 100k, check wheel hubs, check ball joints.
B
bondservant2
Outside of the Blackbear tuning I’m pretty up to date on all the 100k mile parts replacement. Didn’t think about 02 sensors....thanks.
With changing the gear oils over to RedLine last week I also dropped the trans pan and changed the filter and added a drain plug for future fluid exchange.
I was under the impression the K2500 trucks had a trans cooler.....it does have the tow package.....
Yes, yours will have the external transmission cooler, engine oil cooler and power steering cooler too. Also should have ITBC, JL1. When BlackBear does a tune, Justin also modifies the performance of the transmission. For me, this was my favorite part of the tune and makes the truck so much more enjoyable to drive. Among other things, this entails pulling back on torque management and making the shifting between gears happen quicker, meaning the time it takes to shift between 1st and 2nd for example faster than normal at whatever speed.
Maybe we can get them to elaborate? @BlackBearPerf
The 2500 is already about as stout and durable as necessary, just keep up on maintenance.
It would be cool to see if you can add the software improvements that came out in '12 and '13 to an earlier year. Towing prowess would be improved with Trailer Sway Control, Cruise Grade Braking - Normal Mode, Powertrain Grade Braking - Normal Mode and even Hill Start Assist.
Your truck has two fuel tanks. I always wondered why they put the little 26 gallon tank as your main when the 1500 Suburbans have a 31.5 and of course wonder if the bigger tank would fit under yours. I also wonder if your secondary tank above the spare could be made to fit above my spare but that's a separate topic. An extra 5 or 11.5 gallons would be nice when towing.
avalonandl
Troy, MICH & Naples, FL
All the 2500's have the trans cooler. If you live in a state where salt is used the power steering cooler is in front of the radiator upper left. Mine on my Avalanche 2500 rusted out. Drop the trans pan and change the filter.
intheburbs
SE MI
I had Blackbear tune out about 50% torque management in the transmission on my 2008 2500. Made a big difference.
Regards to "bulletproofing," it already is. Change the fluids religiously, garage it, and wash/rinse the undercarriage several times each winter if you live in the salt belt.
My '08 has 196k miles and has lived its entire life in Indiana and Michigan. Very minor surface rust on the undercarriage and no body rust, and mechanically, she's all-original. Hell, I haven't even had to do a brake job in the last 100k miles.
shegarty
Check your fuel and brake lines for corrosion.
For sure ... my 08 Burb here in Canada is on its second set of replacement brake lines. The PO opted for cheap steel lines. I had to replace them again after they rusted out and blew a leak. Used the NiCop lines this time so the rest of the truck should rust out before I have to do the lines again.
whaaaaaaaaaaaaaaat? mind. blown.
I just thought it was a straight 36...lord knows my wallet feels that punch when it comes.
The GMT400s, even the 1500s, carried 42 gallons. Wish mine carried more, it rides better with weight back there. Since the last hurricane threat, my tow gear has been in the back along with 80 pounds of charcoal and know if that stuff is removed she'll get a little bouncy again. Will have to empty it out as Thanksgiving is coming up and will be hauling the chow down to my parents' home this year instead of eating at ours.
intheburbs
SE MI
It's actually 39. I remember when gas prices were over $4 a gallon. One time I filled up at a place that capped pre-pay swipes at $50. Had to swipe three times, for a total of $140.
BlackBearPerf
Supporting Member Supporting Vendor
Coeur d' Alene, Idaho
We would be happy to help with a tune! With transmission tuning, some of the things Justin (the tuner) can do are, shift points and torque converter remapped for better response, desired shift times shortened and shift pressures increased, transmission downshift delays can be removed.
Wilmington, NC
Have you changed the Trans Fluid previously - Normally it should be changed about every 30K. Transfer case and Diffs should be changed out also at 100K - Use synthetic GM products when you can. If it's never been changed, I would hesitant to chance it at this point.
Meccanoble
Georgia
I dont recall the interval ever being that low, even when driven/towed hard. I thought it was closer to 100k for trans fluids but 60k or so would be playing it safe.
Transfer case is 30k I believe while diffs are also at 100k.
OR VietVet
Willamette Valley
Recommended maintenance intervals come as severe driving and normal driving. If you read the fine print you will likely find that you don't drive in the normal range. MOST people qualify for the severe range and maintenance work is done at quicker time and mileage intervals.
ya no way in Hell I would run my transmission or any fluids 100k without a service, even though it could go that far that's just asking for trouble
intheburbs
SE MI
Wow, short post, but yet you managed so much bad information.
The GM owners manual for the OP's truck states trans fluid should be changed every 100k with "normal service," and every 50k for "severe service." Not 30k.
Same owners manual states every 50k for the transfer case. Not 100k.
Owners manual also states synthetic for the rear axle, not "when you can." And it actually does not state any recommended change interval.
And lastly, FFS, please stop spreading the "it's never been changed, so don't bother doing it" myth. If you accept that statement, you're basically resigning yourself to a transmission failure. "The fluid is completely shot, has no lubricity and the additives are gone, but gosh, let's keep running it!" That's a guarantee of the transmission failing.
Even if a transmission has 200k and it's never been serviced, change the fluid. One of two things will happen:
1) Fluid is changed, everything works. You're ahead of the game.
2) Fluid is changed - transmission fails. Unlikely, but this was going to happen FOR SURE if you didn't change the fluid.
I beat the crap out of my truck, so I do the trans (flush), transfer and axles every 50k. Since the power steering also powers the brake system, I've also had that replaced twice, at irregular intervals. Truck is at 195k and is still all-original. I fully expect it to go at least 300k.
One more thing - don't think about coolant changes in the context of "will it still protect against cold temperatures?" Think of it in the context of "does it still provide lubricity for the water pump?" Letting your coolant go too long will lead to premature water pump failure.
B
bondservant2
As mentioned I bought the truck used with 117k miles from a Dealership. There were no maintenance records so I had to go by cosmetics and overall appearance to get an idea of what type of care it received. It’s in VERY good to excellent condition - otherwise I would not have bought it.
I have to agree with intheburbs on all points. Yes a neglected component is not a good idea but to NEVER service it is worse. I did a pan drop fluid change rather than a flush and will drain /replace the trans fluid a few times before next summer (I added a drain plug to the trans pan).
This is a pleasure vehicle and will mostly sit in the garage until needed and then will go out on long vacation trips. But that doesn’t mean it will be neglected. I’m too OCD for that.
Also thanks to intheburbs for suggesting the DuraTrac tires when I asked about tire replacements....found a smoking deal on a set and though I was a bit worried they would be too aggressive, they really ride nice and look great. I did have to remove my front mud flaps though because they rubbed because of their height. Oh well....
Conedaddy
