Help lift kit for 38 or 40" tires ?
Omar 20
Hey guys wussup ?
I am planning to buy a used Yukon XL 2500, the model may be 2007 or 2008
And I am planning to do a lot of mod's and custom things.
My first big question : I wanna run 38" M/T 15.50 wide tires on 20X12 or 22X12 with 40" tires. I prefer Kelderman lift kit but It is only available for HD trucks.
I need a front solid axle ? Dana 60 is good then what to do ? Please I dont prefer fender trimming !
Thanks
InTruckDesign
SW CT,
If you "have" to have a solid front axle then your choices are very limited and will require custom work and fabricating. Now if you want to stick with IFS I would look into Cognito, FTS, BulletProof...all make BIG lifts.
Max
Mile High
Denver
Cognito and FTS make kits for those trucks, I love all the cognito kits we've done.
boroblack
Hey guys wussup ?
Thanks
If you go that big, I think trimming would be the least of your worries with SAS.
O
Omar 20
I saw kelderman 10-12" for gmc 2500hd and require drop front axle.
So if I did that thing, can I use the kelderman kit ?
cognito has 10-12" but I dont believe the IFS will hold the larger tires !
Who does custom lifts ?
InTruckDesign
SW CT,
Anything involving a SAS for a 'burb will require custom work, you need to search your area for a custom shop that can comfortably do the work. I think you really need to do alot more research than to just think your going to put 38's-40's on it.
O
Omar 20
I don't think it is hard to do it !
Kelderman has 10-12" for Sierra 2500HD requires drop front axle.
So maybe if I bought this kit and tried to install it into the Yukon XL 2500HD
However does Yukon XL 2500HD shares the same frame with Sierra 2500HD ?
and the same IFS ?
Thanks
InTruckDesign
SW CT,
there is no such thing as a "HD" suburban, just a 2500 and it does not share the same frame as the Pickup HD's.
O
Omar 20
So yukon xl 2500 share the same frame with yukon xl 1500 ?
it is not clear that Yukon xl 2500 frame doesnt share the same with 2500HD
and doesn't share with 1500 !
CrashCade
Are you just going for size? Are you going to be wheelin' this thing? It all depends on what you want to do. The '07+ trucks have square wheel wells which means you will never be able to stuff that big of a tire.
There are companies that make the Front axle swap kit...
http://www.offroadunlimited.com/orustore/pc/viewCategories.asp?idCategory=3
I have been toying with throwing the axles from my totaled Dodge 2500 under my '07 so that I know my axles can handle what I want to throw at it.
It seems like doing a SA conversion on the front would be pretty easy.
Otherwise, like it has been mentioned, check out Bulletproof, or Cognito.
MTN_KDA
