Help: Does the 6.2L have Fuel Management (AFM/DFM)?
xycrazy
Does anyone know how I figure out whether the 2021 6.2 Tahoe has the AFM/DFM? I think I remember that some vehicle didn’t get it due to whatever reason. I‘m test driving a 2021 6.2 High Country right now and neither feel nor see I anything related to that. Is there an info screen I need to turn on to actually see it? In my current 2017 Yukon I see a small green Box that either says V8 or V4. How do I figure it out with certainty?
Basically, I want to know if the engine is equipped with fuel management technology. It has start/stop if that helps.
Thanks
TrueAt1stLight
Minneapolis
What does your window sticker show? Also when I’m going in and out of DFM I can hear a distinctly deeper engine note when in V8 mode.
Thanks
The engine should be an L87 and if so, it has DFM, meaning it can run on any combination of cylinders as the computer decides.
X
xycrazy
Window Sticker says nothing regarding DFM. I read that some 5.3 engines didn’t get the DFM due to chip shortages. Wasn’t sure if that happened to the 6.2 engine as well.
you can order a 5.3 without dfm as of about a week ago anyway, but it was not currently a option for the 6.2. look in the owners manual it should define when it will enter dfm and how you can tell. It must show on the screen somewhere.
Brand0n
I didn’t realize you could order without DFM on the 5.3. Are most doing so for custom orders? Might have to modify my order…
WalleyeMikeIII
Sunny and Snowy Minnesota
It does not show anywhere where you are in/out of DFM, is all background.
Brand0n
After reading dozens of lifter failure threads on Silverado forums there doesn’t seem to be a consensus on whether ordering without DFM / using a pulsar prevents the failures…guess I’ll role the dice with DFM.
sanman28
Well that’s a bummer. Was going to be my path with my new at4 6.2
tagexpcom
My 2021 Yukon Denali 6.2L owner's manual has this short section on "Dynamic Fuel Management" How do I tell "if equipped"?
veteran111
