OK 5th gear avoids AFM but what about just staying in 4th for around town under 45 mph?
MarvinVR
Tigard Orygun
I asked ChatGPT (I know I know) about every way possible to extend tranny life. He said to help them with their makeup----LOL But seriously folks, Here is what Chat said about staying in FOURTH around town.
The 5.3L Vortec does have a respectably wide power band compared to older small-blocks, thanks to improved airflow, variable valve timing (in some years), and electronic throttle management. But whether staying in 4th under 45 mph is a good idea depends on what you care about:
If the goal is strong throttle response
Staying in 4th under 45 is actually decent. In 5th or 6th at low speeds, the transmission tends to lug the engine — you tap the pedal, and it may hesitate or need to downshift. Holding 4th keeps RPM high enough to respond immediately.
If the goal is avoiding AFM (4-cylinder mode)
Yes, 4th basically kills AFM entirely because load and RPM conditions no longer match AFM activation requirements. That’s why many owners use 4th or 5th to keep it in V8.
If the goal is engine longevity
Running 4th around town is fine. You’re operating in the engine’s normal efficiency range. Slightly higher RPM = slightly more wear, but nothing meaningful for a well-maintained 5.3.
In fact, some would argue that not lugging the engine below 1500 rpm is better for long-term wear, especially on a motor prone to AFM lifter failures.
If the goal is fuel economy
Staying in 4th around town will cost you some MPG. Not a massive penalty, but measurable.
  • In 4th, RPM around 45 mph might be ~1,800–2,200
  • In 5th or 6th, maybe ~1,300–1,600
Lower RPM burns less fuel… assuming no AFM and assuming the engine isn’t lugging.
If the goal is transmission sanity
The 6L80 is happiest when it isn’t constantly shifting up and down. Holding 4th in town reduces constant gear changes. That can be better for valve body and clutch pack life if you drive in stop-and-go traffic.
My blunt conclusion
Driving in 4th under 45 mph is:
  • mechanically safe
  • improves throttle response
  • avoids AFM in most cases
  • costs a bit of fuel
  • reduces shift hunting
Marky Dissod
If you find that when YOU manually shift to L5, the transmission hunts between 4th & 5th more than YOU'd prefer, then YOU use L4.
L5 might be enough for others. 'nuff said.
kikeap
