Ok, I searched for a similar problem to the one I'm having with my Denali with no avail. Here's what's going on: Got this vehicle recently and I know it has been sitting for a couple years without much use. I have been going through it ensuring everything works and noticed the A/C is inop(no refrigerant charge) and the temperature of the air coming out of the vents with the temp selector on the hottest setting is not even warm. So I checked the heater hoses and control valve and broke the valve when I disconnected the hoses to it to check for coolant flow. That is when I noticed that with the engine running, there is absolutely no flow of coolant on the heater hoses at all! While I had them disconnected I went ahead and flushed the core and found no restrictions, so we're good there. Installed a new heater control valve, topped the coolant off, brought engine to normal operating temp, around 200*F and still have no heat to the core. The hose coming off the intake manifold with the quick disco fitting is hot at the connection and all the way to the core but the return hose is not even warm. I know that nothing is clogged up since I triple verified that already, and all I can blame now is the water pump since the flow is non existent. Am I right with my diagnosis? I doubt there's an air pocket causing this but it's possible, and I'm not to familiar with the bleeding procedure on a Vortec, if there is one, I'd like to know how to do it if y'all don't mind to share the knowledge. Also, the PO replaced the ever-failing intake manifold gasket set before but he could not be certain if that's when the heater failed to operate correctly. Engine runs great, reaches normal operating temp like it should, top radiator hose gets plenty hot and pressurizes and the cooling fan moves a lot of hot air through the radiator core. I know one of you has been through this and knows the fix, time to share my friends, holler!
