Heater core hose to water pump
mijohnst
Good morning, Gents!
I'm replacing my water pump because whoever replaced it before me didn't seal it correctly, and it has been slowly leaking. I've done this on other Tahoes, so it's not a big deal. While removing the hoses, I *think* I noticed that whoever did it before might have mixed up the heater core hose lines. The way it is currently connected (looking into the engine), the right core hose is connected to the left port on the water pump. Shouldn't it be that the right hose connects to the right port? I'm hoping this is making sense. If that's correct, it might explain why I'm hearing gurgling while running the heater.
I can't find a diagram of the hose layout on a 2001 Tahoe, so if anyone has one, that would be great.
As always, thanks again!
Moderator
People's Republic of Colorado
2004 shown. YMMV I think the ports on the water pump might be different sizes.
mijohnst
mijohnst
Thank you both for the responses!
The picture shows that your lines are connected right to right, left to left...but the diagram shows how mine is currently connected.
mijohnst
mijohnst
I'm concluding that it doesn't make a difference. I've watched about 10 videos about replacing these hoses; some are right-to-right, and some are right-to-left. I'll switch mine to right-to-right and see if it solves my gurgling problem. If I'm wrong, it's only expensive anti-freeze that I'm wasting. :)
mijohnst
mijohnst
So, I was going to do Scotty's suggestion, but after swapping my lines from what they were, my core stopped gurgling. The left core port goes to the left water pump outlet and the right to the right. I pulled this image off a YouTube and it shows the correct layout.
2006
I have the same setup in my 2006 Tahoe. Is the hose number 3 a molded hose? I replaced mine with a regular hose and it seems like it might kink in the bend near the pump. If it is molded, what is the part number for it? I can not find one.
Bwaldron
