Headlight-Turn signal replacement help!
TahoeHump
My current OEM headlight and turn signals are showing a lot of wear, dull and just look like crap. I want to replace these with a good aftermarket replacement, something that will go in just like the OEM ones do. I'm looking for suggetions on ones to buy and ones to stay away from. There are a lot of them on ebay but its hard to tell which are junk! I'm open to changing the look to something cooler but I want to still use the stock bulbs, no HID or Halo. Thanks in advance for your input!
chauncey0337
MLT, WA
Alot of people like the depo headlights mostly because they are great for hids out of the box but will work fine for halogens. I'm just not sure if they use the stock bulbs. Otherwise, I think most oem looking reflective housing should be ok.
veteran111
