Hello,
I've got a 2001 Yukon with stock headlamps and can't figure out why the low beam on the driver's side aims significantly higher than the high beam. I haven't done the official aiming procedure at 25' and using measurements, but the low beam is clearly off. Parked about 15 feet from my garage door I adjusted the low beam down to even with the passenger side. Looked great until I switched the high beams on and the drivers's side was then way low. I pulled the headlight assemblies on both sides and verified that the bulbs were properly seated but the problem persists. Anyone ever seen or heard of this?
Sincere thanks for any help.
