Has anyone use Mobil 1
zieglerj-pdm-specialist
in 100 degree sandbox
Has anyone used Mobil 1 0W-30 in your 6.0 Yukon Xl Denali. Basically I don't do any hard working with my Denali its more for show. 23" rims Neon lights in the grill. Just a show boat and I was wondering if 0w-30 would get me better gas mileage than 5W-30.
shakedown067
I doubt it's going to net any better gas mileage. Personally, i don't think it'd hurt the motor any, but I don't have any real data or experience to back that up. If anything, it'll find any weaknesses in your gaskets and could end up with an oil leak.
clandr1
Dallas/Fort Worth, Texas
I'd stick with 5w-30. No need in running lighter weight oil than spec'd, especially if you live in a hot climate.
edited to add: I've run Mobil 1 High Mileage 5w-30 since my truck had around 80k on it, and no problems.
Chiggy
Kansas City, MO
I'm a firm believer in using the oil that the manufacturer designed the engine to run on. Things like your bearing tolerances, rings, oil pump, filter, lifters, and so on were designed with a certain oil in mind. The only reason I would switch grades is if I was in a very hot or very cold climate and working the engine hard, and then I'd look in the manual to see what they recommend. I use Mobil 1 5w30 and change the oil every 6k miles or sooner.
SLCHOE
ASE Master Certified + (L1)
Midvale, Utah
This. Your engine is designed with a certain oil spec. Changing the viscosity of the oil will affect oil pressure because oil clearances in your engine are designed for that viscosity oil. Going thicker or thinner affects how oil flows through these clearances in main/rod bearings, piston/cylinder walls, etc.
I run Castrol Edge Black Full Syn and change at 3K miles. Wix filter also.
sbubbaklein
House Springs, Mo
I run 5w30 mobil one in all of my vehicles. I believe it has outstanding performance for vehicles that sit for periods of time.
FrankU
Babylon New York
I use Mobil 1 5W-30 Extended Performance Full Synthetic Motor Oil with a good filter and nothing else.
ezdaar
Chat Troll
Redneck central, Aka Houston
Everything in one location.
Best mobile one, Valvoline and filters..
From the pos PF48 to the big dog PF63 wich is now standard OEM replacement.
As well as the best Wix filters.
Click here
Plenty of other goodies in my 29 wish lists as well :)
As an Amazon Associate we earn from qualifying purchases.
selahpartners
