GMC Yukon Lift
jerseyjonny
Jersey
as everyone else has said you can spend a couple of hundred dollars on keys and leveling kits and tires or you can spend a couple grand on a thru and thru lift and put good size tires on it. it all depends on what kind of money you are looking to spend
msbailey
High Point, NC
Lug nuts on BBS wheels
What kind of lug nuts did you use when mounting the bbs wheels? I just got a set of BBS RD wheels and I have been told I have to use a flat washer style lug nut and not concentrical. The flat washer is hard to find in a 14mm x 1.5.
yukon2004
San Antonio, Texas
thegeneral
I just had a Zone 6" lift put on a 2000 Yukon Xl
They say it retains the factory ride, I have to say they are pretty close.
I also installed a ranch hand legend Grille Guard, MT baja ATZ 35's and pro comp wheels.
I drove it down Highway 17 from Santa Cruz to the bay area and it felt very similar to stock (except for sitting 11" higher)
I would recommend Zone lifts to everybody...
One problem I have found is that the 35's are rubbing in the front, at the back side of the tire. (on the inner fender) I'm sure this is a problem with most 6" lifts and 35's, but figured I should throw it out there.
Here are some pics.
johnsonwillie199
