GMC Yukon Lift
dg527
DFW
Tons of info on lowering a Yukon, but very little on lifting one. Has anyone lifted their 4x4 Yukon or Tahoe? Any info would be welcomed on ride quality, brand, price, etc...
I know it's a soccer mom/grocery getter vehicle, but I'm trying to masculinize this thing somewhat.
Thanks in advance.
BlizzardX23
Sacramento, California
too easy...but...it all depends on your budget..and how high you wanna go....
skys that limit...unlike dropping it...you can only go so far before you bottom out lol ;)
Rollin Thunder
Banned for Repeatedly Insulting Members
Va Beach Va
Im sure lots of people have just not here, most lower here for some odd reason. Pretty puch, Rancho Or procomp are my two favorites for lifting.
AquinoSteven
Key and Spacer Guru
Clinton, NJ
keys and spacers is the most popular route. You will be able to fit 33s with some minor trimming. 6in will fit 35s and anything bigger is a little much for a grocery getter
BlueTahoe2001
Charlotte, NC
Yeah best bet is to check out Rough Country Leveling Kits. RC makes a kit for Yukons that is $260 Comes with Keys, Rear Spacers, and Shocks
D
dg527
DFW
I've cranked on the torsion keys and brought the front end up. I'm going to look into going to a 285/70R17 tire. I'll need new wheels with more backspace if I want to go bigger.
Turned in the man card and gave up my 3500 4x4 Cummins for this Yukon. Trying to undue some of the douche factor of driving a stock SUV.
Max
Mile High
Denver
Ford keys, 2" coil spacers, and bilstein 5100 shocks front and back will clear a 33" tire with the proper offset. I don't like lifting these trucks unless you do an 8" kit or larger
http://cognitomotorsports.com/store/GM_6-Lug_SUV.html
00-06-10-12-lift
ryangt
double team supreme
Jacksonville, Florida
im in the process of doing the keys ( superlift) and 1.5 spacers in the back with 285/75/16 tires on the stock wheels, should look nice. It all depends on the lift you are going for. Are you going for the "look at what im compensating for " look or for something you can actually use offroad.
D
dg527
DFW
Both, I want the look and the capabilities. I know this isn't a rock crawler, but I want to feel comfortable out on the trails.
A small increase in ground clearance while maintaining a somewhat stock appearance is what I'm after.
ecordell
CordellDesigns.com
Merica
the only way you're gonna gain ground clearance is bigger wheels/tires, just so you know.......
99chevytahoe
I talked to a local tire company, and they said i could fit a 285/75/r16 on my stock Tahoe. So is this not true, I currently have 265's on there now and there doesn't look like there is too much room left so i don't know anymore?
djohnson1
yep, can easily fit 285/75/16. got a set of nitto terra grapplers and i got to work a little bit to rub. grant it i dont get real wild but ive been up some pretty washed out roads with a lot of trenches and only rubbed a few times. didnt touch the keys or anything. the only thing i did was i pulled the front of the front driverside fenderwell forward just a little bit with a bit of wire. cant tell its there and gives just enough clearance to keep it from rubbin.
AquinoSteven
Key and Spacer Guru
Clinton, NJ
I just did a 2" leveling kit all around for under $100. Im still running 265s but we test fir 295s and i could clear them no problem. Im going 285s on my next set.
haha yes the running boards are "off". Im waitin to pull them any day now
Kat Killa
Just bought 1"-3" lift keys of ebay for $65 shipped. Put stock rear springs back in and should have a set of 295/70/17 Terra Grappler AT mounted this weekend. Of course w/pics. Edlebrock has a sale on shocks right now. $25.87 a piece w/free shipping. These are for cranked keys or up to 2" of lift in the front. Use "catalog2010" in the code for free shipping. About 20 guys on GMFS have bought these & say they are great shocks for 1/3 the price if Bilstiens. GMFS has a much larger group of lifted trucks for reference also.
AquinoSteven
Key and Spacer Guru
Clinton, NJ
Thats what your truck would look like. Hes runnin ford keys and 3" ebay spacers on 33s. The white z71 has a 3" body lift on 35s.
D
dg527
DFW
I ordered the Truxxx system with new keys and spacers for the rear. Once installed, I'll upgrade to 285's. I'll post pics when the install is complete.
Truxxx 404012 if you're curious.
midmohoe
columbia mo
if you have about 3 grand to spend i would recommend rough country 6in lift i thank i got mine for 1300 shipped to my door and shop around for tires and wheels i found a set of 35 12.50 20s on craigslist for 500 bucks and they are practically brand new and a 1000 for wheels not a hole lot of money for a good looking hoe u can see a pic of mine in my photo album
D
dg527
DFW
Got my Truxxx system installed and found some 20" BBS wheels on craigslist.
johnsonwillie199
