GM Entertainment and Comfort Serial
smurphy80
Hey guys, I recently installed a PAC GM9-AAI in my '02 Yukon so I could have my XM thru the Aux input of the Cassette deck. Only problem being is that you need to have a tape playing in the cassette for the thing to work...well my tape player is shot. Is there anyway to feed voltage to or drain voltage from the serial bus at the tape player so as to TRICK the radio into thinking the tape player is playing? Atleast I assume that the serial bus is what is telling the radio there is a tape playing. Any ideas anyone?
theautoman21
I do believe there is a wire that is for the radio on. no its the green and white wire which is the remote playback i do believe that might be it one of those should do itand there is a purple wire too its a control wire and then there is black and white wire for the on signal and also dark bluie is for the remote radio control and i think that might be the one your looking for i hope this helps i have been triing to get this dvd head unit with factory amp to work i have it working minus the rear speakers i also am putting in a new and bigger sub plus another amp to run it and haveing a hard time becuase some reason the amp will not work first it was lack of power then i had it working for a minute just aminute seems crazy and its been almost a month and still havent got this system going all the way yet its in a 01 tahoe. hope this helps
dizhai
