Georgia Mountain Rough duty Tahoe. The struggle is real.
OneofFew
OneofFew
Talullah Falls, Ga
I also rebuilt the door hinge on the driver side. Looks like some moron had the door off before and wanted to fix the issue but instead of replacing pins and bushings, decided to hammer on stuff.:banghead:
The was a tricky job, especially since the PO had stuff all turned around. There are 2 styles of pins that seem to be interchangeable... Ones with snap rings at the end and ones with nuts. I am undecided which is better. getting the snap rings off and on really was easy.
After adjusting the striker bolt to the now level hanging door, everything closed like a dream.
Steadily progressing!
I'd verify the oil pressure with a mechanical gauge. Between the possibility of a wonky stepper motor in the cluster, oil pressure sensor, the circuits in between the sensor and gauge or a clog in the sensor or screen behind it, you'll never know for sure without an independent gauge.
Tylus
South GA
any updates? I too am putting a 01 'Burb back on the road that'd been neglected. similar brake and suspension story. 282k and still runs strong lol
Drewphil
