Gas Leak Fix
TahoeGoBoom
blue interior guy
damn, sorry to hear its bein a pain in the ass. it should all be better in the end tho.
ravingmadman
Chief Knuckle Buster
Greater Seattle
Damn dude. There's a poltergeist running around screwing with folks who have '99 hoes. I just blew the valve guides in my K5. Yay.
TahoeGoBoom
blue interior guy
NO! dont say that i may be next. lol. And i've got a vette servo install to do tomorrow. maybe i should hold off til the poltergeist thing blows over.. lol
96ProCompTahoe
IN
haha. well the rest of it went really well other than getting the stupid filler hose back on. things a PITA.
carrier and pump came right out, got the pump switched over to the new carrier, and back in it went. strainer on the original was nasty, but it was all still GM factory parts. made it to just over 175,000 miles. (pump is still going) new tank breather things went right in without any problem, cut all the new hose to size, hell the wiring harness was even factory spec, no splicing, no ********. that tank is one TIGHT fit in the 2-doors. had to wedge it back up with the floor jack, new strap bolts.
drove it once and filled her back up. so far no gas leak. got a few pics of the carrier and the pump assemblies, the assembled tank, and other misc i'll put up sometime soon.
get to pick up the radiator for the IROC in the morning, hopefully i don't hit any snags with that.
96ProCompTahoe
IN
well it was doing great until the pump shit out on me last night about a quarter mile from the house. $70 tow charge. new Delphi pump went in it this afternoon. took about an hour and a half to drain all 30 gallons back out of it and about an hour to drop the tank and change the pump. Greased the shit out of the fittings to hopefully keep them from getting like they were if i ever have to drop it again.
Delphi Pump -Napa
Pump Carrier- Autozone (only one who had it)
Hoses- Napa
Tank Breathers/Returns/whatever they are called- O-Rileys
Strap bolt kit- O- Rileys
Filter O-Riley's (not installed yet, nuts are frozen yet again. project for another day.)
ravingmadman
Greater Seattle
Make dern sure you're getting proper current to the pump. Just don't blow yourself up. That's frowned upon here.
96ProCompTahoe
IN
no i ended up not replacing the pump, just put it in the new carrier. (needed the $ for the camaro's radiator) it just came back and bit me in the ass a day and a half later.
96ProCompTahoe
IN
Tank when it finally touched the ground. notice the snapped off tubes...
The old carrier assembly after the pump was removed
New Carrier Assemby with old pump installed
New carrier installed in tank with new tank breather/returns and hoses.
Lines Hooked Back Up
THEN THE BEST PART THAT HAPPENED ABOUT 36 HOURS LATER... :biggun:
THATS WHAT YOU GET WHEN YOU DON'T REPLACE THE FUEL PUMP... so after about an hour and a half hand pumping 30 gallons of gas back out of the hoe pulling the tank back out again and dropping in the $100 Delphi Pump shes good as NEW!
Overall changing it all out is easy as HELL once you get the lines undone. Anyone with basic tools and a jack can do this. don't pay the dealer $800 for this crap. :idiot:
mr. yuk
newport, nc
Thank ravingmadman, not replacing a fuel pump but yeah:
http://www.tahoeyukonforum.com/forum/showthread.php?t=1810
We need to start getting some of these threads stickied.
same procudure for an 01 too, but they left out, drop the back of the tank 1st and make sure that you dont try to lower the tank with your leg as it will be pinned under because gravity makes what fuel that is left in it go to that end. i would still be under there if my wife wouldnt have heard me yelling to go get my prybar. :shocked:
briannorris
