gas door not releasing
992dr
Eastern N.C.
The spring or whatever the mechanism is does not work and the gas door is now setting inside the door opening instead of flush with the body. And I need to use something thin to pry it open.
Never had an issue with this before and was wondering if anyone has had this happen?
If so, do you have a part number or schematic on what part failed? Did a search and found very little info and a partial print.
Thanks
Big Mama
Virginia
The Hong has a spring on it to open when you pull the handle inside. Sounds like you need a new one. Look on Rock Auto. You can get just the frame with hinge and spring. I’d think one of your hinges broke and slipped into its pocket.
kbuskill
NE. FL.
Thanks
https://www.amazon.com/Genuine-GM-20912532-Fuel-Spring/dp/B00GV8S4BC
Depress 2 tabs and pull the old one out... pop new one in and enjoy.
992dr
992dr
Eastern N.C.
Thanks man, I appreciate the info. Though I'm not sure what a "Hong" is :)
That's it? I wasn't expecting it to look like that.
Cool, thanks a bunch.
Big Jim
