Full "neon" escalade third brake light
Mickey_7106
Bay Area
Bought this bar from amazon for about $210 Shipped. This is the look that i planned on achieving when i bought an oem esky light over a year ago. It's made in Taiwan and its a decent looking piece. It's painted "black" but from up close its a real dark gray. Cant really tell the difference from a short distance. I have some terrible pics of the oem light next to this new one
AmeriLite Red Neon LED 3rd Brake Lamp Center High Mount Stop Light for Chevy Tahoe Suburban/GMC Yukon XL/Cadillac Escalade - Passenger and Driver Side https://smile.amazon.com/dp/B08FSZM...abc_N1PHK2TT2XX8P6J62TJ6?_encoding=UTF8&psc=1
Smoked
AmeriLite Smoke Neon LED 3rd Brake Lamp Center High Mount Stop Light for Chevy Tahoe Suburban/GMC Yukon XL/Cadillac Escalade - Passenger and Driver Side https://smile.amazon.com/dp/B08FT8JTKG/ref=cm_sw_r_apan_glt_fabc_0BEY1G6HKAWQ277JDC7E
St. Louis
I bought an Eagle Eyes brand one about a year ago for about $180. I saw your link to the newer ones and noticed they have smoked lenses now and ordered one so it matches my tail lights and head lights. Supposed to be delivered tomorrow and I'll probably get it installed this weekend with before/after pics.
Mickey_7106
Mickey_7106
Bay Area
Received my smoked high mount stop lamp/spoiler today. Looks decent and was packaged well. There's a few rough edges along the bottom edge of the lens where it meets the housing, but probably won't be that noticeable when on the vehicle.View attachment 350498
Almost bought that one but i like the red bar going across and i wasn't sure how many lumens I'll loose going that route
Mickey_7106
Mickey_7106
Bay Area
Probably a week and I'm starting to have problems. It appears the plastic might have expanded under the sun and now it hits the roof of the truck trying to open it. I tried adjusting it as far down as i could which wasnt much and it can open all the way but it barely kisses the roof along the way
I
St. Louis
That sucks. What Temps have you been seeing lately?
Mine's been on a couple days but the Temps have only been in the 80s and cold front moved in today so only 60s-70s the next few days.
Looking at the underside and comparing both spoilers that I have when I was installing it, they are identical except for the light/lens part. They both unbolt from the back and completely remove and I could've swapped them from one to another if I wanted.
I've had the unsmoked one installed since December 2019.
Are you using the 3 stock bolts with the built-in washers that use a torx bit or the screws/washers that came with the spoiler?
Mickey_7106
Mickey_7106
Bay Area
The highest has been 85°. I used the stock bolts. When i unscrewed the 2 10mm nuts it looked like the spoiler relaxed a bit. I can open the glass and gate now, but slightly bothered thats its kissing the roof.
Keanen55
HOUSTON, TX
That's odd. I've had 1 for over a year and no problems. Looks great at night! I'm in TX with 100 degree temps! Must be a bad unit! Sorry to hear that you're having issues!
I swapped my eagle eye one I bought a couple years ago into a stock esky housing and sold the eagle eye housing with a chrome putco lamp to another member, they reported that the eagle eye housing had warped a couple months later.
Mickey_7106
Mickey_7106
Bay Area
Installed the replacement and it was crap too. It looked like it was bubbled in the center and it was only a matter of time before it started to bump on the roof. Also some areas around the bar were looking a bit warped or distorted so I wasn't any happier with this new one .
I ended up swapping the light bar to the oem spoiler i had and was a much better fit. I believe there's something wrong with their mold. I got 2 different lot numbers and they weren't fitting properly
Amerilite spoiler. Notice how it sits a bit higher than the roof.
<<-------Front. Rear------>>
The escalade oem spoiler with full bar light
<<------Rear. Front ------>>
Mickey_7106
Mickey_7106
Bay Area
It was hard to capture a good pic of the warping look, but it was behind the second and third mounts screws. Screwing them down would pull it in giving it an un-even look. It was very minimal on the oem spoiler
Both Amerilite spoilers. Im trying to point where it sinks in.
Oem spoiler with Amerilite full bar.
St. Louis
Damn, that sucks. What brand is your spoilers, Amerilite? Is that the name of the seller or maker of it? I know mine are Eagle Eyes brand. Do you have a pic of the underside?
Here's a pic of the sticker on mine with the model/lot #s20210916_160542.jpg
Mickey_7106
Mickey_7106
Bay Area
Amerilite is the seller on Amazon, no idea who makes it. This is the first lot they sent. I didn't take a pic of the second but did verify that they weren't the same.
Brace
