fuel pump problem?
96skyjacked
I have a 96 tahoe 4 door LT. 5.7 automatic, I had the hoe in the shop getting my cd player fixed up and my buddy was looking at my door pin problem. They couldnt get her started to pull it out, and tried several times for about 45 minutes before I got there. It was running when I got there. I guess they put some kind of pressure reader on her and it was reading at 44 but should be around 66-68?? They suggested I need a new fuel pump and guesstimated it at 300 bucks parts and 100 labor.
After some research on my part, parts should be around 100 or less. Plus I found that there are 2 different setups. 1 fuel pump frame mounted, or 1 fuel pump tank mounted. How do I know which one I have?
And my truck has been acting normal since I picked her up, Ive always had a little trouble cranking her up but the hoe always starts for me. Is this something I should replace preventatively to avoid trouble on the road?ANy help in this matter would be greatly appreciated. Thanks
fyremanpat
Fyremanpat
Fuel pump is in tank. Its not that hard to replace if your you're almost on empty (due to weight) . Get your new pump from Napa its OEM. Does your pump whine with the key in the on position? If so its definitely your pump...they are notorious for going out on these trucks
04SS99Denali
NY
this is how i did my fuel pump on my silverado lol
but with all seriousness i know you cant do that on a tahoe just make sure you have very little gas in it and it shouldnt be hard at all
96skyjacked
no whining, it just hard to start sometimes. and then sometimes it will sputter while driving and i feel it through the gas pedal.
fyremanpat
Fyremanpat
no whine? I didnt think my old pump whined until I put a new one and heard that. possibly a relay going bad then. but im willing to bet its the pump
riviera rider
change your fuel filter mite be clogged, cheap replacement mite as well try it out first!
ravingmadman
Chief Knuckle Buster
Greater Seattle
Go to the tech section. I did the write up. It's not difficult, but you'll need a weekend, a friend, and a lot of beer. I wouldn't replace it till it really dies, frankly. My $0.02.
:drunk:
fyremanpat
Fyremanpat
yea when it finally dies and leaves you stranded on the side of the road... its only a matter of time
TheBeast99
ya, i'd get it done as soon as you have the money for it.
45 minutes is a lot of cranking and praying when you want to leave work after a long day ;-)
ya, i just had mine done a week ago. My OEM pump cost $127 and labor was a lil over $400.
My pump was whining when i got the truck in Nov '09, so who knows how long it was whining to begin with.
but ya, you got a 96, so it was bound to go eventually - heed the warning sign.
ravingmadman
Greater Seattle
Oh, and you or your friends reversed the costs. :) It's roughly $100 for the pump, and 3 hours of shop labor, or 6 if you're doing it for the first time on your own. I did mine by myself, asking the wife for help when I needed someone to laugh at me. Good times, good times....
---------- Post added at 02:28 PM ---------- Previous post was at 02:26 PM ----------
also, I'd drop the tank, and look at the wires. Typically these pumps don't decline in efficiency before dying, they usually just quit completely. You might have a poor contact supplying less than adequate power to your pump.... But either way, if you replace the pump, you'll fix it, me thinks.
:drunk:
cdhpc2
