Fuel Composition Sensor (P0178) - SOLVED
Multnomah Falls
So, parts replacement DID fix the problem? Roadtest results and how long or far on the roadtest?
RAMurphy
RAMurphy
Bob
S. Maryland
@OR VietVet So for reference, prior to replacing I cleared the code several times and would get the code again within driving 2-5 miles after my baby was warmed up. I would get two codes, both P0178, one actual code and then the pending. After the change, I still smell like gasoline, no codes after 5+ miles.
Multnomah Falls
Drive it. Unless you have a fuel leak from you messing up the install. You are still smelling the fuel spill.
It would be interesting to see what the ethanol content reads now, especially if you know how much (if any) is in the tank. Maybe fuel trims, too.
pikelk98
