Hows it going... just bought a 03 gmc Yukon Xl denali. It has 168000 miles on it I got it for a good deal because it has a couple problems the main problem is a grinding/ winding noise coming from the front drivers side.... I originally thought it was a wheel bearing which would not be a huge problem to fix but it seems to only whine whenever I'm on the gas. It is a awd truck and it sounds like my jeep when its in low range 4x4. I'm having trouble. Troubleshooting the problem I thought id see if any of you guys had ran into this before. I'm thinking its gotta be a bad bearing somewhere. Carrier bearing? I just hope I haven't gottin into a mess. The other problem is the fuel gauge...the low fuel light works and the estimated fuel range works but the gauge is on E. Not a big deal but id like to fix it. Thanks in advance - jake
