Front Door speaker installation
lowrhadur
2002 Gmc Yukon 2wd Non Bose 102,000 miles prettywell stock.
Replaced the front door speakers in our yukon.
Factory paper speakers were not much more than
frame and dust.
For reference here is a breakdown of what wire is what. I found this on the forum here and this is what i went by. Everything seems to be right.
LF,- gray
LF,+tan
RF,-dark green
RF,+light green
RR,-light blue
RR,+dark blue
LR,-yellow
LR,+brown
Batt,Orange
Ignition,dark green
These are off the bigger plug
There is anouther plug with
dark green/white
pink
gray
dark green/white
brown/white
black/white
black
dark green
orange
this is for your remote cd/tape if you have one.
Remove window switches. Should pop right out if not, carefully use a small flathead screwdriver.
Unplug all wiring.
There are 2 screws that hold the door in place. (one behind controls and one above door handle. Remove these and panel will slide right up.
Once panel is off, you will need to unplug the tweeter and light.
Next you will remove the factory speaker.
I am installing a componet set so this install is a bit different from a coaxil setup. If you were installing coaxil's you would just mark and drill your holes, install the speaker and put everything back together.
The speakers i am installing are a 6 3/4" (oversized 6.5") kicker ds65.2
I removed the screen on the door panel, removed and modified the factory tweeter bracket, installed the new tweeter.
I chose to mount my driver side crossover under the dash above the ebrake release.
I started by fishing a piece of 12gauge solid copper through the wire loom going from the door to the cab. put a bend on the end of the wire and it will make for good fishing.
Use a flathead screwdriver to pop loose the loom where it connects to the cab.
work the copper wire up to the other end of the loom.
fish your wires through the hole in the door, tie them to the copper wire and pull them into the door.
from there hook up your factory speaker wire to the line side of the crossover and hook your componet speakers up to indicated wires.
will update this when i have more time.
L
lowrhadur
I have more to post on this install. I will do the same when I replace the rear door speakers, pillar speakers, and factory subwoofer.
---------- Post added at 04:11 PM ---------- Previous post was at 04:09 PM ----------
Will be a few days before I finish it up as I lost a close friend last night. I will finish it up soon though
electro
Kitchener, ON, CAN
What are you planning on using for a replacement subwoofer?
I have not found a subwoofer to fit into the stock housing yet.
Most time the aftermarket sub is too deep.
:cheers:
L
lowrhadur
I just replaced the sub with a 8" RE Audio DVC 4ohm. Had to take the rubber trim ring off the sub and trim about 1/4 of an inch all the way around the sub. Siliconed the opening really good and mounted the sub. Took about an hour. Sounds WAAAAY better than the factory sub. No depth issues but wish I would have spent a few extra bucks and gotten a little better sub
electro
Kitchener, ON, CAN
Well that is nice to hear that it sounds much better than the factory sub.
I want to do something with the sub for sure in my truck.
I have a 4 channel 400W amp I am thinking about putting in and powering the front doors and rear doors.
Not sure what to do with sub yet.
How much did that sub cost ya?
L
lowrhadur
Just under 50.00 shipped.
S.L.A.B
houston TX
how do those kickers sound compaired to stock bose? im debating between these and focal 165a1's
---------- Post added at 06:39 PM ---------- Previous post was at 06:37 PM ----------
How do these kickers compair to stock bose? im debateing onn these and focal 165a1's.
02GMCyukon
Can't compare really, stock Bose were completely rotten with nothing left. But I am 200% certain they sound atleast 201% better than the stock. :) buy them, you won't regret it. I got mine from amazon for 64.99 shipped.
tRidiot
I have spent extensive time rebuilding my inner doorskins. Finally at this point, I have a set of 6.5" (more like 7" really) monster Exodus Audio Anarchy midbasses in there, one per door. Each is in a custom fiberglass enclosure which slides into the doorwell itself and is mounted to the inner metal doorskin. Then the factory doorpanels go back on to keep everything appearing mostly stock.
It's been hell trying to get really good solid midbass out of the Tahoe doors. I mean hell. I think we've rebuilt these 4 times. Next time, I'll be having custom fuberglass doorpanels built with pods for either 2-3 6.5s or a couple of high-output 8s, or even a 6.5/12" combo.
I'm a fanatic about midbass/up-front bass. Currently running 400W per door just to the midbasses. These trucks are pretty difficult to get good hammering midbass out of, much more difficult than my previous 240sx, where I had an 8" in each door and was in Nirvana...
Drewphil
