Front Dash Crack
harveje
I worked thru a gm ert for our cracked dash in an 08 yukon and no joy.....out of warranty out of luck.. at least the ERT took time to try..
okfoz
The Dash Caps have been around for years and years. A friend of mine with a 1974 Datsun 240Z got one for his car. It looked better than the broken up dash, but I could always tell it was a cap.
Years ago, they used to make a vinyl & leather repair kit, it was a rubbery compound you would mix and try to get the correct color, then spread it on the material and there was this piece of vinyl they would send to use as a pattern. I wonder if something like this would work for the dash cracks... use it like a bondo, and then make an impression to get the texture... Wouldn't be perfect without painting the entire dash, but it might look a little better.
If/when this happens to me, I would still personally consider going to an upholstery shop and see if they can cover it in vinyl.
John
codster
2007 Yukon Denali just purchased used. I haven't tried calling GM yet.
akbrener
Baltimore, MD
if they wont fix my 2008, i bet they will laugh harder at your 2007. The customer service lady at two dealerships i talked to while working with corporate GM both said the goodwill on dashes is not likely unless it is still under warranty
07 Tahoe
Texas
Same issue. Cracked dash on driver side on back side of the cluster hump. Just dealing with it but would love to have it replaced if all possible.
LoHoe
Yea i doubt mine would get fixed. Im out of warranty. How much does the dash cost?
hokeyplayr1986
Mines is cracked as well
Yea I have one crack just like one of your pictures from right around the passenger air bag cover. Also another partial crack right behind the instrument dash hood. Sucks.
14SWTahoe
Tampa FL
Thank You GM for finally getting it right, my 2014 Z71 has no cheap plastic....
Its tough to tell for sure, but from the up close pictures of the cracked dashes being posted in numerous places, it looks like the same dash in my '14 Z71.
though there is a new part number assigned for the part starting 2012 and up. who knows if that is a better part or not or if that revision had anything to do with the cracks. As the 2012-2014 age we will see if it make a difference, too early to tell.
fiatdale
Houstons Best
Houston
The 2012+ has a different texture to the outside of it. Its a bit softer, less glossy finish than before. As far as the under side goes, the mold is exactly the same as the previous models. Possible the coating reflects light better to not cause heat distress? Dunno. The ones we've been replacing still go via year. So if a 2009 comes in, we replace it with the standard dash PN, not the new one. Don't ask me why. They do pay well to put in though, so I have no problem with needing to replace them!
nahfwt
Is there any reason the 2012+ dash wouldn't fit in a 2007-2011 truck?
alnjessie
2010 Denali Cracked Dash and door handle issue
I have a 2010 GMC Denali with cracks all in the dash...it started with a small crack at the subwoofer speaker and spread all the way up toward the driver instrument panel. GMC should recognize this as a defect in this vehicle along with the cheap door handles that break and come off the vehicle as well. I called GMC recall center and told them about everyone online having problems with this and a possible class action lawsuit they are now paying for me to bring my vehicle in to be checked... if they get bombarded with all of us pulling together we can get them to issue a recall.Everyone affected by this problem should start calling them and don't stop until they address this. I will update everyone as it all plays out.I am at dealership now and since it is the GMC dealership they are trying to brush it off..I am suppose to call the GMC recall center when I get home to update them of the dealerships findings concerning my dash. I am ready to start a class action suit. If all of you that have this problem would email me with your name and contact info and spread the word on other sites concerning this... I will contact and get a lawyer to handle our case and make GMC stand behind their very expensive product that they are not backing. My email is [email protected] Please help me in standing up to make a difference. will update more as to what GMC recall center tells me.
brice715
