Found the Rear Blower Problem, now what to do about it?
WildernessJeep
Houston, TX
So after buying a new resistor, figuring out that wasn't the problem and volt checking everything, I finally pulled apart the connector next to the emergency brake. It is burned and damaged inside both connectors of the plug.
Is there a way to replace the entire plug, or should I just wire around it?
W
WildernessJeep
Houston, TX
That's what I figured. Any guesses what the red/yellow/black wire is? I got this truck secondhand. Is that wire stock?
varminpoolteam
