First Yukon had 24's on it when I bought it
Firsttruck
Hi guys, complete Newb here...
This is absolutely my first truck of any kind. Before this I was into street legal drag racing and owned a 2004 gto with a 408 cubic inch motor with a 150 shot of nitrous on it. Well along comes a woman and children so things changed the goat had to go and I needed a family vehicle. I found my 2005 Gmc Yukon with 93,000 miles on it and paid $11,900 for it. It came with 24" wheels already on it and also came with the stockers. I live in Iowa so I thought it was a good deal to have the stockers for the winter time.
I immediately changed oil and filter and will be changing transmission fluid within the next few weeks. I inspected the vehicle about as much as I could when I first looked at it. The tires on the 24's are 305/35 r24 and looked in great condition with about 85% of the tread on them. After doing closer inspection crawling around under the vehicle over the next few days I noticed the inside of the tires had been rubbing on the rears. One of them has chords showing on the inside drivers side rear. I did some calling around and found a place to get a new 24" tire mounted which took a while living in a small town in Iowa this isn't common. I also did some calling around and ordered some H&R spacers for the rear because I don't want to keep cutting tires at over $300 a piece. I checked the fronts and there appears to be no rubbing and even at full turning radious there appears to be plenty of room.
I'm a little dissapointed I have to run the spacers, but for a quick fix so I can get this thing back on the road for our family vacation it should get me by. The truck is stock suspension and with the spacers the rears will stick out past the fenders slightly. I don't believe this is a problem in Iowa as far as legality because I see it all the time in my small town. Also the vehicle will not be seeing off road, but it will see some bad winters which I have the stock wheels and could remove the spacers at that time for the snow and ice.
I'm just curious if anyone has any thoughts on this issue?
---------- Post added at 10:18 AM ---------- Previous post was at 10:11 AM ----------
Oh, also on the subject anyone have jacks and jack stands they recommend for changing tires/working on these suv's? Like I said this is my first truck so I have a small hydraulic jack and small jack stands I use when I work on my cars, but I don't have a good setup for working on this Yukon.
I will also say I really liked changing the oil and filter on this thing didn't even jack it up just crawled under it with my catch pan...lol...easiest oil change ever.
[/url][/IMG]
ghost
Senior Member
[/url][/IMG]
take a look at this thread. is this what its rubbing on? theres a few things you can do to fix it if it is.
http://www.tahoeyukonforum.com/forum/showthread.php?t=35280
F
Firsttruck
Ya, from looking at it I would say that has to be where it is rubbing. I've only had the truck less than a week so I don't know how long it took to wear the tire the way it is or under what conditions it is rubbing. I'm not sure if it's on heavy bumps, with a heavy load, turning or what, but I want to get it addressed right away.
From reading the link you provided it looks like the best cheap option is to grind it. About how much material should I take off? Also I'm thinking I need to smooth up the edge after I take enough material off just in case it does rub a sharp edge would cut the tire faster/worse than a smooth edge even though any rubbing is going to hurt the tire.
Thanks for the response man!
F
Firsttruck
Welcome man. looks like a nice clean truck.
Sent from my iPhone 4g using Tapatalk
Thanks, my camera is giving me fits not allowing me to upload some better pictures right now so I'm limited to my cell phone pics. It's got a small tear about 1 1/2" long in the seem of the drivers seat, but other wise interior and exterior is in great shape.
I really don't have much info on the service history of the truck so I'm going to work my way through changing various fluids and changing plugs over the next few weeks. From visual inspection it looks like it has a brand new alternator, belt, and battery in it. So far all I have done is oil and filter change and put a new air filter in it.
F
Firsttruck
I got the grinding done last night and sprayed some under coating on it so I will be able to see if it still rubs and where by watching where the under coating gets rubbed off. I also rotated tires while I was at it.
Buster6
Iowa
I'm in Oskaloosa south east Iowa
Fellow Iowan here as well. From a small town in the southwest part of the state, but one of my best friends lives in Osky. I, too, just bought a Tahoe. Enjoying it so far.
scottd
