Feasible/advisable to replace pads but not rotors?
LurkingLuke
WA
What's the chief drawback or concern? Trying to save $ but not in the mood to take two steps back after one forward.
Use your own personal judgement if the rotors are nice and smooth with no grooves or glazed, then new pads and good to go. Just did my rears few days ago the rotors were perfectly fine, they had maybe a tiny smidge of glazing nothing for me to worry about. I just wanted to swap the pads real quick took me about 20-30 minutes and didn't have to run the rotors across town to the truck shop to get turned.
Marky Dissod
You likely don't brake aggressively enough to worry about it.
If the rotors are still thick enough, go ahead, but remember:
Don't forget to bed the new pads in, once installed.
Might be a good idea to clean off your old rotors before installing and bedding in your new pads.
strutaeng
Dallas, Texas
You check the rotors with one of the those HF dial indicators. If they are within specs (and not rusted out badly), then there's no reason to replace them. I believe there's a spec for run-out as well as thickness and parallelism (you need a *********** micrometer). You can just do a scuff with sandpaper for proper bedding with the new pads. I think the Haynes Manual advices to do this? I don't think that actually does anything.
Marky Dissod
I think the Haynes Manual advises to do this? I don't think that actually does anything.
It does.
Brand new (naked) rotors don't have any pad material on them.
Brake pads transfer some pad material onto the rotor once they reach a certain temp, this is what bedding the rotors is for.
Brand new pads on old rotors, the old rotors need their surfaces cleaned to make it easier for the new pads to transfer pad material to the rotor.
petethepug
Michael
SoCal
I was going to say if you had drilled & slotted rotors the discs clean themselves. Then I see this …
Proof is in the pudding. Slap those new pads on and apply the supplied grease to the backside and ears of the pads.
dizhai
