Electronic box under drivers seat.
Steek
What is the small 4"X3" metal box with wires, under driver's seat. 1995 Tahoe, 2wd?
CIA blackbox :secret:
seriously though, not 100% sure on that year but typically it is the airbag module (which is technically the "blackbox"), or some other module to that effect.
it should have a part number on it. Not sure if the 95 had a yaw sensor or not. that would be a possible module under the seat or center console.
S
Steek
Thank you Wes;
Found a Model # 16211311, Serial # 3000712
Can Thid further help? If not thanks anyway, I appreciate your time.
Thank you Wes;
that is the radio amplifier. It being under the seat is unusual must have been a gmt400 thing at one point. in 2000 it was moved to behind the glove box and then later moved the under the center console then more recently it is now in the rear drivers quarter panel
BadDaddy2003
