Ecm-1 fuse issues
Sean99c3500
i have a 1999 c3500, 5.7 4l80e
I was messing around in the fuse box the other day and accidentally pulled the ecm-1 fuse and it shut the truck down. Ever since I haven’t been able to get the truck to start again. When I first crank it she tries to start but as soon as it does it dies again
Was looking into a few things and I know I’m getting spark to the plugs, and it will stay running on starting fluid.
It’s got a whole new spider injection system along with fuel pump and everything. I’m not sure what’s causing the injectors to not fire properly. I used a NOID light and as I crank it sends power fine but once it starts the injector pulse is very intermittent. Any ideas?
floater
Canada
Have you disconnected the battery and let it reset everything? Sounds like the passlock system is shutting off your fuel pump. Can also try the passlock relearn. Google it.
scottd
