Disclaimer: Links on this page pointing
to Amazon, eBay and other sites may include affiliate code. If you click them and
make a purchase, we may earn a small commission.
I want to put duals on my 95 tahoe 350 tbi. I want that deep but not annoying sound. Should I run two straight pipes with flows or one pipe split into two pipes for duals.
IIRC, the 95s came with a single converter... assuming you're still running the factory setup, it'd be cheaper to install a SI/DO muffler with split tails (or run a y-pipe off the converter) - the sound will be about the same either way.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
