DRL not working after conversion
karel k
London UK
Hi All
Driving a Tahoe 2007 in the UK, there's not many other owners you will meet and can talk too about issues. ( I think there are max 50-100 in the UK). I recently had the garage convert indicator lights to amber for UK registration (using reverse with amber bulbs)⁰⁰, and reverse and fog light modified.
Now, I am a bit puzzled about if anything happened to my DRL: front DRL is working fine, but I am 99.9 pct certain the rear lights also were on as DRL, but not working at the moment .
Is there anyone with a standard Tahoe 2007-2014 that can tell me if the rear lights are supposed to switch on as DRL , when it is daylight ?
Thanks !!
no rear with DRL only, with engine running press the fog light button and then you will get rear with the fogs & drl
you will need to do this each key cycle if you want rear on.
also you will only see front DRL while in "D" drive and parking brake not applied.
Hodmjstone
