Driver's seat movement
Scottdog
Hello all. First-time poster here.
Just wanted to see if anyone else had an issue with the driver side full electric seat moving up and down on the door side of the seat. I can see where its moving and my mech said that its suppose to move there so the front of the seat can be raised, but its moving every time I accelerate or brake?
Any ideas? Thanks in advance!
SunlitComet
OBS Jedi-Do Good
unknown at this time.
:welcome:
Moving like how much.
---------- Post added at 02:44 PM ---------- Previous post was at 02:42 PM ----------
I could under stand a little play but you say it like it is a lot more that.
---------- Post added at 02:45 PM ---------- Previous post was at 02:44 PM ----------
any chance of pics?
---------- Post added at 02:46 PM ---------- Previous post was at 02:45 PM ----------
And the seat too:)
Scottdog
Scottdog
Only about two or so inches, but its enough to annoy me... lol
SunlitComet
OBS Jedi-Do Good
The hell with that, you must have broken a structure part, track, gearbox or seat bolts. About your mechanic.........................
Scottdog
Scottdog
HAHA! I know how it reads, but if you actually LOOK at the spot where its moving, you can see that the movement SHOULD be happening, just not that much. Ill snap a picture of the place where its moving, yeah? Would that help?
Scottdog
Scottdog
Easy, killer... :)
Here is the pic. The arrow shows where the movement is happening.
Its normal for it to move, but not when you arent moving it with the controls....
SunlitComet
OBS Jedi-Do Good
Not near my truck right now so can you get a pic of seat normally as if you were parked and one with with it moved? It is kind of hard tom make out with the pic above.
Scottdog
Scottdog
You got it, man. It might take me a bit. That picture is with the seat in the normal position. Ill post the other soon. Thanks a lot for the help!
SunlitComet
OBS Jedi-Do Good
If there are no broken joint that you can see. I am thinking a motor controlled link in the motor assembly broke letting the linkage for that side to go up and down freely.
Scottdog
Scottdog
Here are the pictures. The first one is in the normal position, second one when I have grabbed the seat and pulled up:
SunlitComet
OBS Jedi-Do Good
As I see it the problem appears to be on the right side of chair. The cross tube in the front look to be twisting when the seat is pulled up which to me it looks like it pivot function is still there but the mechanism that raises the left side is not attached internally, broke inside the gear box that moves that cross bar. I think when you pull it up and down and watch the bar on the right side of seat move you will see that the bar moves but the rest of the right side components don't. At that point I don't think it is repairable. You would have to replace the motor gearbox assembly.
Scottdog
Scottdog
As you are looking at the picture, the driver's door is on the right. So, youre saying that the motor that makes the front of the seat raise is bad?
SunlitComet
OBS Jedi-Do Good
When facing forward the motor/gearbox assembly is on the right side of chair. I see the pictures you posted of the left side where you see the big movement. What I am saying is I think the actual broken part is in the gearbox itself or just outside it as show below in the red box. Not really the motor itself, however I don't think you can replace just part of it last time I looked at the parts list. I believe is is only available as one complete unit.
Johnnyboy677
