FFTodd
so i'm new to the forum and joined because I just bought my wife a 2015 (used) Tahoe today. I did some searching and couldn't find anything previously covered, so here's my issue-- I'm not sure if there is a problem with the driver window or if this is some feature I don't quite understand...
When I use the auto-up feature the window rolls up to the closed position, and then rolls back down about halfway and stops there. The only way it stays up is if I hold the switch halfway to raise the window until it closes. The other 3 windows behave as I would expect. The only thing I can find in the manual that could be the problem is the possible need for reprogramming of the window motor. I've tried following the directions regarding that but can't get it to change anything.
Any ideas? Thanks for the help.
