Drilled/slotted rotors
arveetek
Granby, Missouri
I put new brakes on the front (rotors, pads, calipers, hoses) of my Tahoe around 10,000 miles ago, and I've already got warped rotors again. I used the regular parts supply rotors. I'm thinking of swapping to some drilled/slotted rotors to keep them from warping again. I think the cheaper (probably Chinese) rotors just can't stand up to my wear and tear.
Any recommendations on where to buy/what brand to buy?
I have the 6-lug rotors.
Thanks,
Casey
fyremanpat
Fyremanpat
personally I wouldnt go drilled, slotted maybe. your best bet is get decent (not chinese haha) rotors
TahoeJim
SE Ohio
I bought the NAPA Ultra Premium rotors that are drilled and slightly slotted. I live in the mountains and the stock rotors would warp up every single time I drove on this one road with a long, winding, steep decent. The Napa rotors have been on for about 17,000 miles and not a hint of warping. Nice that NAPA is everywhere and they come with a lifetime warranty.
Ignore the description stating they're 5 lug, they are 6 lug as the pic shows.
http://www.napaonline.com/Search/De...+4014032+5999999+502003+502999+504506+504999#
96ProCompTahoe
IN
i have a set of brembo slotted stock replacements on mine and they are awesome. noticed a huge difference over the stock slick rotors
oldsalt
Just received Powerslot's and Hawks. Will put them on next week. Figured I'd give them a try. Been running Brembo's (not slotted) and Delco pads for years.
The most important thing is to hand torque the lug nuts. They must all be even. Go slow when tightening. Doesn't hurt to loosen a bit and re-torque them every few thousand miles.
bowtiefreak
No Quarter
Near Philly
Powerslots + Hawk pads.
I run a slotted drilled rotor and hawk pads on the tahoe and I love them. I used to warp crappy rotors all the time. I just ordered some powerslots and hawks for the suburban, I should have them on next week.
Something to keep in mind is that it is possible to warp the rotor by using an impact wrench (putting them on in a circular pattern) to put the lugs on versus the correct star pattern method. A giy we race with who owns a body shop told us that...haven't had the problem since.
TahoeJim
SE Ohio
Brembo or Powerslot Slotted rotors. Don't use auto parts store brand.
I have 17k miles of mountain/very steep road usage that seems in direct contrast to your statement. All of the GM emergency responder vehicles here in the mountains also are outfitted with the same NAPA rotors when the stockers warp.
I'm curious why you'd issue a blanket statement like that.
noJeepshere
Bountyfull, Utahrd
Agreed with Kris, avoid made in China crap. I also use NAPA for almost everything parts relpacement related. It's the only store in town here that has car guys that know what they're doing, and the stuff is pretty quality.
A
arveetek
Granby, Missouri
Thanks guys!
Here's a response I received from another board:
"You should look at new calipers instead. I imagine you are already running vented, because that is the way to go. Slotted rotors came to be as a way to vent the build up of gases between the pad and rotor. They have been obsoleted by newer pad material, although are still used with extremely soft, aggressive pads. Cross-drilled rotors will increase your stopping distance quite a bit because all of the holes significantly reduce the swept area of the rotor. Additionally, the holes reduce the strength of the rotor. Their main purpose is to allow for the largest possible pad and to keep the sprung weight down.
Basically, if you continue to warp rotors, check other areas before going to a rotor that will decrease your braking performance."
I thought that was an interesting response. I had the understanding that drilled and slotted rotors were always an upgrade?
Casey
noJeepshere
Bountyfull, Utahrd
Makes sense though if you think about it. I would do just slotted rotors as they'll do all the work you need them to, unless you're going tall with a lift and big tires.
When my brother sold me My Yukon, it had practically brand new brakes all around, and if you look at the fronts, after 55,000 miles, they are only half gone, but they warped almost immediately after I bought it. In a year or so I'm upgrading to larger slotted rotors with a hydroboost setup, along with discs out back.
SunlitComet
OBS Jedi-Do Good
unknown at this time.
Because they make the choice based and price for that purchase not total cost ownership/operation. You actually spend more over time and use inferior products. Using better products with longer life, performance and reliability can save you money. The shop just thinks the drivers will always burn them up so just get the cheapest they can get on account. Why not itrain the drivers to not abuse the vehicles and use proper braking techniques. If you need extra braking use transmission/engine braking. Why do you think we use thrust reversers on aircraft?
---------- Post added at 06:33 PM ---------- Previous post was at 06:30 PM ----------
No drilled rotors either. They crack to easily from drilling stress.
A
arveetek
Granby, Missouri
I'm the only one who removes the wheels from my rig, so I know that the wheels have been tightened in the star manner. I always criss-cross in several steps with my impact gun. I have to admit that I haven't used a torque-wrench. I know I should.
Also, that's good to know about the drilled rotors. I always thought that drilled AND slotted were the way to go.
Thanks guys!
Casey
dizhai
